what do you think of this combo
Old Jan 31, 2006 | 09:13 PM
dab2pds's Avatar
Car: 05 corolla xrs, 05 hayabusa, 91 rs
Engine: 383
Transmission: t56
ive got this engine and tranny built sitting on the stand about to go into my 91rs.
383 stroker, 4 bolt main, 10.89:1 cr.
edelbrock performer rpm heads, hs 1.6 roller rockers.
performer rpm intake.
cam: duration @ .006" 308i/318e
duration @ .050" 234i/244e
lift .488i/.510e
hei distributor.
holley 750 double pumper with mechanical secondaries.
t56 6 speed. 3.08 peg leg rear end(will change as soon as possible).
is the 750 dp too much carb for this? what gear ratio would you advise for this setup as a street/strip driver? thanks.
Old Jan 31, 2006 | 11:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The carb will be marginally large enough.
Gears: 4.10's or 4.56's.
Old Feb 1, 2006 | 02:35 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i agree...carb will be about right, or go larger the 950 hp is nice but pricey. also 4.10s or larger gears and just run 28" slicks as needed if mph is overshot with 26" tires. the 28s should be good for another 7-8mph at the top end if you run out of RPMs
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
