quadrajet
Old Feb 20, 2006 | 12:38 AM
hawkwilliam's Avatar
Car: 83 trans am
Transmission: t5
Axle/Gears: 323
quadrajet
i have a qjet always fat, rich so this mechanic says he fixed it but i would basically have no choke, mecanic quit his job and its out of wack any ideas?
Old Feb 20, 2006 | 01:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what?
your q-jet is running rich? cc qjet?
you'll need to tune it up and rebuild it. I didn't get much info from your post, so what has been done here?
also, stock engine underneath?
Old Feb 20, 2006 | 02:12 PM
Car: 83 trans am
Transmission: t5
Axle/Gears: 323
not stock
carb probably only has 3k miles on it, over a 350 with weiand intake, lunati cam, hooker headers
it was running rich, took it to a mechanic, he leaned it out (he said, and said i would have trouble with it in the winter because it has basically no choke now) the dude is no longer with that garage, and true to his word, it seemed leaner but won't start for shizzle in the cold, have to pump the gas, then hold it to the floor, until warms up
what i would like is some way to tune the carb back to a more versatile point, working whether it is hot or cold....
i live in indiana, and have no emissions check, so that doesn't matter
Old Feb 20, 2006 | 02:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get yourself a $30 carb rebuild kit, a $10 float, a $15 can of dip-type carb cleaner, and if you don't have an air compressor also get a couple of cans of spray carb cleaner to blow out passages after the dip cleaning.
Go through the carb, epoxy over the well plugs if they aren't already ( for details), put it back together per the instructions in the kit.
Old Feb 20, 2006 | 03:47 PM
Car: 83 trans am
Transmission: t5
Axle/Gears: 323
google?
epoxy over the well plugs (search?) do you mean google it?
Old Feb 20, 2006 | 04:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not google, but the search button at the top right below the sponsors' ads.
Old Feb 20, 2006 | 04:27 PM
Car: 83 trans am
Transmission: t5
Axle/Gears: 323
thanks
Old Feb 20, 2006 | 09:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
a mechanic tuned your carb, and you lost your choke feature? (I guess he used that to help tune it somehow...?)
I wouldn't trust that guys knowledge of q-jets then....
Yea, rebuild it yourself, with instructions that come in the box, search on this site for info on rebuilding, then if you're REALLY stuck, post again
Old Feb 20, 2006 | 11:22 PM
Car: 83 trans am
Transmission: t5
Axle/Gears: 323
thanks guys
yea, the mechanic even said, "you need to find an older dude who works on these things", guess he cost me some moolah in the end
Infested
May 22, 2018 11:56 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Thaney9
Aug 29, 2015 03:16 PM
