Strut Braces - Carb
Old Mar 26, 2006 | 01:43 AM
Demon355's Avatar
Strut Braces - Carb
I know a few of you guys have them, but the search is down, mind posting the pics again?
Old Mar 29, 2006 | 05:03 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I made mine but I should have made a bump out for the air cleaner. now I have to decide if I want to make a new one or just get a new air cleaner.
https://www.thirdgen.org/forums/atta...4&d=1115151776
Old Mar 30, 2006 | 11:47 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
cadillac has a sweet one, let me see if I can find a pic...
Old Mar 30, 2006 | 12:08 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Are strut braces worth the time and money spent on them? If so i'll def. be fabbing a set up!
Old Mar 30, 2006 | 07:42 PM
Car: '72 Chevy Nova
Transmission: TH350
That's cadillac's stb. Very sweet.
STBs are definetly worth the money
Old Mar 31, 2006 | 04:08 AM
Demon355's Avatar
Thats the one I was looking for, good find and thanks!
Old Mar 31, 2006 | 04:20 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Just a heads up: If you buy one of those Edelbrock 3-point strut tower braces to put on an LG4/L69, you'll need to relocate your AC compressor to the passenger side (as shown in the picture above) for the brace to clear. If you don't, it's going to run into clearance problems with the compressor and will not install correctly.
Old Apr 2, 2006 | 10:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Nate86
JIf you buy one of those Edelbrock 3-point strut tower braces to put on an LG4/L69, you'll need to relocate your AC compressor to the passenger side (as shown in the picture above) for the brace to clear.
I've been waiting on Spohn (or another manufacturer) for several years to fab one of these up. Got to be a ton of people who'd purchase them.
JamesC
Old Apr 2, 2006 | 07:08 PM
head's Avatar
Car: 1984 MSE #52
Transmission: TH700
JamesC
ME TOO !!
Old Apr 3, 2006 | 01:11 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Will the Edelbrock 3-point fit with an LS1??? If not which ones will? I assume there is more room than with the TPI...
Edit..sorry...I did a search for STB and didnt realize it was posted in the carb forum until I came back to check it... Ignore my question Ill keep lookin!
Justin
Old Apr 28, 2006 | 02:31 AM
CamaroMike's Avatar
I fabbed my Edelbrock STB to work with my 84 LG4 belt set up. If ya wanna know how just let me know.
Old Apr 28, 2006 | 02:43 AM
Nate86's Avatar
Engine: 4 cylinder
Yes, I would like to know.
Old Apr 28, 2006 | 05:51 AM
JamesC's Avatar
C'mon, Mike, spit it out
JamesC
Old May 2, 2006 | 12:27 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
another request
Old May 4, 2006 | 01:11 PM
CamaroMike's Avatar
Sorry about the delay. Here ya go. I took an Edelbrock STB for TBI and cut the welds where the cowl and strut tower bars meet. I then flipped the strut tower bar over and rewelded it to the cowl support bars. The STB now juts up from the strut towers instead of down. Some vehicles have enough hood clearance to add spacers under the strut tower brackets so you do not have to flip the strut tower bar over but this really depends on the vehicle. You will also need to remove the bar bracing the upper A/C bracket to the intake manifold. The upper A/C bracket can then be notched for STB clearance. That's it.
Old May 4, 2006 | 01:33 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
does the STB only fit with stock manifolds, or with aftermarkets, too? because of the higher waterneck.
nebu
Old May 4, 2006 | 02:26 PM
CamaroMike's Avatar
I am running an RPM Air-Gap with no problems.
Old May 4, 2006 | 07:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
urbanhunter44:
Where can one acquire this Cadillac STB? Got a part number? Cost?
Old May 5, 2006 | 12:07 AM
85_ZED28's Avatar
Car: '85 Z28
heres my 2 point Jamex stb
J-money
Jan 4, 2019 09:45 AM
Fox118
Sep 12, 2015 09:29 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
89 formula TPI
Sep 8, 2015 08:00 PM
Ian Irvine
Sep 4, 2015 08:08 AM
