air gap intake, stock hood
Old Feb 23, 2005 | 09:27 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
air gap intake, stoke hood
I,m putting my motor in this weekend. The thing is will a air gap intake and carb fit under a stoke hood and is the air gap better than the regular performer?
Old Feb 23, 2005 | 11:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The Air Gap is a better manifold, performance-wise, because it will keep the intake charge cooler, because the ports and carb are not in contact with the same metal that is covered in hot oil, or has hot coolant passing through it. It also has no exhaust crossover. Also, the fact that air can pass through the outside of the manifold would also have a cooling effect too.
As for fitting.... Camaro or Firebird? What carb are you using? What air cleaner are you using?
I'd actually like to know the answer to this as well, because I've been toying with the idea of getting one to replace my Torker in the spring.
** forgot to ask... 'Performer Air Gap' or 'Performer RPM Air Gap'? It may or may not make a difference, I dunno, but can't hurt to have more info.
Old Feb 24, 2005 | 12:50 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It fits, but you have to use the right air cleaner.
Search my posts: keyword L-88
Old Feb 24, 2005 | 07:24 PM
RacerDonnie13's Avatar
Car: 1988 Camaro SC
Engine: 383 Stroker
Transmission: TH-350
i just put a carbed motor in my 88 camaro with the Performer RPM air gap intake and a Holley 750 double pumper. I went ahead and bought a cowl hood for mine because it didnt look like it would fit once I put the air breather on. But im sure with the right carb/air breather combo you could make it fit.
Old Feb 24, 2005 | 08:42 PM
Car: 84 Z28
Engine: 383
air gap
The intake is a Performer Air Gap intake. I'm useing a Edlebrock 600cfm carb. The air cleaner is a drop cleaner. Oh yeah, I alson am not going to use any spacers what so ever. As soon as its in I'll let u know Air_Adam. Hope it works. Will know Sat.
Old Feb 24, 2005 | 09:46 PM
Air_Adam's Avatar
Re: air gap
Cool, thanks man. Good luck!
Old Feb 26, 2005 | 10:57 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
with a drop base and a 2 1/4"element,1/2"wood spacer, AND a castle bolt i clear a stock hood without damage in the 86.oh yeah,edelbrock 14" chrome top.
Eric
Old Feb 26, 2005 | 11:03 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
rpm or performer?rpm all the way!
Old Feb 27, 2005 | 01:03 AM
Car: 84 Z28
Engine: 383
Thanks on the spacer size. I'll know 100% sure if it works tommorow. Got old motor and trany out. New trany in. Motor going in tommorow.
Old Feb 28, 2005 | 11:56 PM
rjmcgee's Avatar
For what it is worth the RPM AirGap is 15/16ths of an inch taller than the regular Performer intake. I measured both on my car when I switched them. When I had a 600 Edelbrock carb I had to run a one inch spacer under the Edelbrock drop base air cleaner. The fuel inlet interfered with the air cleaner base. Could only fit a 2 inch tall filter under the hood. Maybe this can be changed but I just saw it as one more good reason to ditch the Edelbrock carb. You put a 2 inch filter in a drop base aircleaner and the lid is probably less than an inch from the top of the carb. Not great for air flow.
With the Demon carb I am running now I can run a 3 inch filter on top of the RPM AirGap and fit it under the stock 86 IROC hood.
Old Mar 1, 2005 | 01:16 PM
Car: 84 Z28
Engine: 383
carb
I ended buying a 600 holly saturday. Thanks fpr letting me know that it will work. Thats great news.
Old Mar 8, 2005 | 04:34 PM
Car: 84 Z28
Engine: 383
It works
Air Adam it works just fine. I put my hood back on today and it fit just perfect. Iused a drop edlebrock breather with a 3 inch air filter. So people who says it want work it does.
Old Mar 8, 2005 | 04:59 PM
Air_Adam's Avatar
Cool, thanks!
Old Mar 9, 2005 | 08:47 PM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
I'm running a holley 750 VS on top of the RPM intake (not the air gap) with an open element edelbrock air cleaner, under a stock Z 28 hood. That air cleaner has more dimples in it than a fat ladys ^$$. Oh and don't buy that filter. It comes apart and cruds up the carb.
Old Mar 9, 2005 | 08:50 PM
Car: 84 Z28
Engine: 383
Do u like the 750? I've thought of going bigger on my carb.
Old Mar 10, 2005 | 06:13 PM
Car: 86 IROC
It is right on and perfect. It's actually easy to go to rich with it but it's tunability is flat out awesome. I love Holley and this VS 750.
Old Apr 10, 2006 | 07:47 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
anyone else get this combo to fit??
I have the rpm air-gap with a summit dropbase air cleaner, demon carb, 3" filter and a stock camaro hood with the blisters. It sure dosent look like it will fit.
I just put in new motor mounts, stock not polys.
Old Apr 10, 2006 | 08:30 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
@bluegrassz: it will fit. look at my sig and the picture. air cleaner has a 1.125" drop.
nebu.
Old Apr 10, 2006 | 08:34 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
nebu.
Thanks. I guess I just need to try and set the hood on. That will remove all doubt.
Old Apr 10, 2006 | 09:54 PM
Car: 84 Z28
Engine: 383
It will fit. The only thing that touches on mine is the wing nut. It has put a little indention in my hood insulator. When u look at the car with the hood off u think no way this is going to work, but it does. The only concern would be the new motor mounts. Mine where the orginals. Let me know if it clears with the new mounts.
Old Apr 11, 2006 | 07:20 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I looked at it again last night. No way the 3" filter will work. It should work with a 2" and still have enough air space.
Old Apr 11, 2006 | 03:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The fuel fitting interfering with the air cleaner housing issue can be solved with a banjo fitting that gets the fuel ine out of harms way.
The overall fitment of a drop-base cleaner can be solved with a Mr. Gasket 1/2 inch plastic riser, and dropping to a 2 1/2 inch element. That way, you'll clear all the linkage and choke stuff, but maintain the same overall height.
This was my solution on my Performer RPM intake (same height as the Air Gap), Edelbrock 1406, and drop-base cleaner housing - it all fits fine under my stock hood.
Old Apr 18, 2006 | 11:31 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
the only air cleaner assembly that worked perfectly for clearance under my stock hood with rpm airgap and holley 650 dp, also when i had the edelbrock 600, and 650 thunder series...........was the edelbrock 10 X 2 open element air cleaner assemby. THe mr gasket 10X2 wont fit.
Old Apr 19, 2006 | 08:00 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Mine fits fine does rub on the hood a little when the engine rocks. 3" filter Moroso low profile assembly and 650 Demon.
Old May 1, 2006 | 02:37 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
did you have to use a carb spacer with yours cuz of the vac fitting on the back?
Old May 4, 2006 | 06:55 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
I use the low profile fitting that edelbrock sells for their manifolds and holley style carbs for my PVC and the ftting on the baseplate for my power brakes.
Old May 5, 2006 | 08:58 AM
SteelTownMadDog's Avatar
I have the Performer RPM QJet, Qjet carb, and 3" K&N with a 1.25" drop base and it fits under a Z28 blister hood...but barely. I checked with the ol' playdoh trick and I have about 1/4" clearance at the front section of the air element.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
