Does it have to stay level?
Old Apr 28, 2006 | 01:53 AM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
Does a carb perform & function best when it stays level?
The reason I ask is this:
I'm building a rod with a Jagaur IRS.
Those axles must stay level to have correct gemoetry. Then the transmission (and the engine of course!) must stay level to avoid vibrations.
The top of my aluminium airgap intake is not level. I suppose that's because most originally mounted CSB motors are leaning a little towards the back of the car.
It is not enought material to change the top surface on the intake.
I haven't bought a carb yet.
What do you guys recommend?
-Don't worry and just leave the things as they are?
-Make an adapter?
-Use an off road carb or somthing?
Old Apr 28, 2006 | 12:12 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
How far off level are we talking here? I dont think youll run into issues unless this thing is way off. You could always build some sort of carb adapter to level it off.
Old Apr 28, 2006 | 07:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The only mention I ever heard about "unlevel" and carbs was in the 4X4 forums, where the guys are standing K5's on their noses trying to rockcrawl - those guys switch to FI so there's no fuel sloshing in the bowls while they are at a 40 degree angle climbing a mountainside.
Old Apr 28, 2006 | 08:17 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
the only time the carb level comes into play on a norally driven car is either when it leans to far to the driver's side or to far the the passenger side.. as then you can not get the floats to adjust right. if the engine leans back or forward it will not matter. as the float adjustment would take care of that
Old Apr 28, 2006 | 08:34 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
the motor and trans SHOULD NOT BE LEVEL they should lean twards the rear
(trans lower than motor) it should lean apox. 2-4 deg. witch will put the carb aprox. level on the intake that is wy the intake is made at an angle. the engine ,trans and rearend should be aprox. oposit angles pinion down 1-4 deg. NOT in line with each outher. U-joints will not functoin properly if they are strate they nead an angle to make the neadle bearinngs in the cups rotate. if they have drasticley diforant anlges front and rear it will vibrate. most carbs will function up to 30 deg. or so without a problem.
Old Apr 29, 2006 | 06:26 AM
Hotrodder's Avatar
Engine: 350 CSB
You are absolutely right about that, but that's not the issue here.
We are not talking about the engine/trans inline with the rear axle. It is about those components being parallell, but at unequal distances from the ground.
An example: If i hold a metal rod level and 30" of the ground and you hold a metal rod level and 20" of the ground, then our metal rods are level and parallell, but they are not inline, right?
Old Apr 29, 2006 | 04:39 PM
how did a simple question of whether or not a carb has to sit level get to here?
It is a simple yes and no question. Yes. It has to sit level in relation to the passenger & drivers side of the car. while it does not have to sit level in relation to the front and back of the car.
Old Apr 29, 2006 | 07:40 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
I can not clame to be an expert on the subject. And I am shure there are exeptionts in diforent aplications but generaly the engine and trans slope down the lowest point in the center of the car and the rear dif. slopes down the lowest point is also in the center of the car. they are not parellel. you should do some reserch the find the corect placement for your aplication.
As for wy I posted the information that I did. I got the imprshion you were doing a custom intall and thout If I could lend some info that mite save some hard work in avance I would try to lend a hand. I tride to explain wy the carb mount is not parellel the intake base.
Old Apr 29, 2006 | 08:07 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
One outher thing if you machine off the top of the intake to make it parellel to the engine the carb bolt holes will be at there original angle!
Old Apr 30, 2006 | 08:02 AM
Hotrodder's Avatar
Engine: 350 CSB
Thank you to all of you. It is valuable to hear other's opinions.
Old Apr 30, 2006 | 05:17 PM
I think you meant if you machine off the top of the intake to be level (by using a level) the carb bolt / stud holes will NOT be at thier original angle and it would probably cause problems when trying to mount the carb for a seal.. more then likely end up with a few vac leaks
Old May 1, 2006 | 04:50 AM
Hotrodder's Avatar
Engine: 350 CSB
I'm aware of this problem.
A possible soultion might be to buy an aluminium carb spacer/adapter, grind it down to a proper angle and make new holes in it for the carburetor bolts.
sheachopper
Jul 31, 2019 11:27 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
