Running too rich
Old Jun 7, 2006 | 10:14 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
Running too rich
How do i get my carb to not run so rich????????????? its a CC Qjet......
Old Jun 8, 2006 | 09:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, it really depends upon why it's running too rich. It could be a weak O2 sensor, improperly adjusted carb, float set improperly or fuel-soaked float, leaking well plugs, mixture control solenoid inoperative, etc., etc., etc.
Is your SES light coming on? If so, have you checked the trouble code(s) being set?
Old Jun 8, 2006 | 06:17 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
well i just installed a brand new o2 sensor...........
and i dont have no check engine light or anything............
the carb used to be on a 305 and now its on a 350.............
Old Jun 8, 2006 | 06:37 PM
five7kid's Avatar
So is mine. . .
Well, you may have eliminated one possibility. I should also have added improper timing/ignition.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
