tbi or carb
Old Jun 23, 2006 | 10:31 AM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
tbi or carb
i have a 91 rs with 350 tbi and 700r4 and i was wandering wich would be better tbi or carb. my only problem is im trying to get more horespower and i already have a carb (holly 750 doublepumper but no intake) or should instead of getting an intake for the carb buy a hop up throttle body and an intake should i splurge for the throttle boby or the carb
Old Jun 23, 2006 | 05:07 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I don't know. I'd run whichever you prefer. But you'll be spending more money than you think on the TBI setup, because the factory TBI unit probably won't get you where you want to go.
Me, I prefer carb, because I can't stand dealing with balky ECMs. But that's personal opinion.
Old Jun 23, 2006 | 05:33 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
thanks the carb sounds better like a simpler way to go anyways
Old Jun 23, 2006 | 07:09 PM
Excellegions's Avatar
Car: 91 Camaro TBI 5.0
I aswell would go carb, much easier to obtain HP than a tbi, tbi just didn't make very much sense to me. However, changing over to carb may serve just as much as a headache as getting HP out of your tbi. Depending on how much power you're looking for, you could always install a spacer between your tbi and manifold, install a rougher cam and reprogram the ecm to get atleast above 250 hp. You're main lose is having a 305 Ci block. I wouldn't expect more from it. Going carb will grant more options in achieving hp, however the clean up of all the ecm wiring and redirecting of the vacuum and emmisions control isn't worth it.
Old Jun 25, 2006 | 12:02 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by camarodrew
i have a 91 rs with 350 tbi and 700r4 and i was wandering wich would be better tbi or carb. my only problem is im trying to get more horespower and i already have a carb (holly 750 doublepumper but no intake) or should instead of getting an intake for the carb...
Are you sure it's a 350 TBI (LO5)? If so, I'd definitely spring for a Weiand "Stealth" intake (there pretty cheap, and work very well). I wouldn't bother with the 750 double pumper, unless you're planning on running an aggressive camshaft in you're near future. A Stealth intake with a non-cc quadrajet, and you'll be ripping some asphalt in no time...
Old Jun 25, 2006 | 06:49 AM
contact's Avatar
Engine: sbc 350
several opinions so far, all for carb,
what is wromg with tbi...
....tbi situation....
for up to 300 HP,
possibly with a new intake manifold, bigger TBs?.
probably needing a new prom.
but with that stuff, you
get the advantages of fuel injection
I don't see problems for tbi until you
start having issues with the injectors
not flowing enough fuel
Old Jun 25, 2006 | 02:38 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
the car came with a 305 i just dropped 350 4bolt in with its own tbi setup
Old Jun 26, 2006 | 06:01 AM
contact's Avatar
Engine: sbc 350
'drew,
Do you have access to someone who can 'tune'?
ok, so the car -305 had tbi, and you swapped in a 350
with tbi? if yes, you should consider keeping tbi.
btw, what cam is in the 350?
Old Jun 26, 2006 | 11:14 AM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
thanks the 350 is stock but fresh and yes i do know someone that can tune but there a** holes should i deal with them or get the carb and yaeh there that bad
Old Jun 27, 2006 | 01:58 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Get a carb. TBI is a step in the wrong direction. There is no real right way to make HP with a TBI other than getting the largest injectors you can, which still are not all that large compared to the lb/hr rate you can get with 8 properly sized injectors. Then you end up cranking the TBI fuel pressure up to 2 or 3 times what the factory designed and having to burn chips to try to get it to idle right.
Old Jun 27, 2006 | 02:43 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I beg to differ, GM ran 32 PSI fuel pressure on the last 454 TBI trucks with two small 45 lb/hr injectors. At 32 PSI they were equivalent to 73 lb/hr each. I have run 45/55/61/and 68 lb/hr injectors at 32-35 PSI with no problems. Chip tuning is not that hard to learn. I have pulled 301 RWHP @ 6,500 out of a TBI 305 with 61 lb/hr injectors and was not out of injector, I was out of engine!
Old Jun 27, 2006 | 06:58 AM
contact's Avatar
Engine: sbc 350
'drew, first of all, consider putting in a decent camshaft,
while you have the chance.
There is no substitute for a good cam.
do a search, you can find out the
issues with going to carb.
you need to think about
. the carb to tranny cable
. what to do with the distributor
.the carb needs a low pressure regulator
. probably other stuff
Old Jul 1, 2006 | 09:49 AM
ckeene502's Avatar
i would stick to the tbi since it is already there. do as much as you can with bolt ons and tricks then move on to changing the prom.
Old Jul 2, 2006 | 01:32 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
dito
i would do this you will really like it
latger
rick
Old Jul 2, 2006 | 01:37 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by Rick King
dito
latger
rick
Dart 215s on my 350 TBI. First startup and the .BIN was a total guess as to what the heads would do with the VE/Spark tables. I have it running much better after a little tuning.
YouTube - 350 TBI
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
