top end help
Car: 91 rs
Axle/Gears: 4.10
top end help
i have a 91 rs with a 350(stock) and i need help choosing a cam intake and carb for a daily driver with the ocassional race or two i like alot hp to brag about and im on a tite budget (just enough to get this stuff)
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
get a dual plane manifold, you won't be flowing enough on stock heads for a big single plane and the extra torque is nice for a car that's driven more on the street than the track. The Performer RPM is a great one.
carb would be near a 650 CFM. I prefer Holley's but you'll hear good and bad about all of them.
If you are truly on a tight budget then a stock LT1 cam is an upgrade to the one you have now and will be really cheap. otherwise look for something in the range of 218in./224ex. @ .050 and keep the lift near or under .525 the stock heads won't flow at much higher lift than that anyway.
ambainb
Apr 25, 2016 09:21 PM
