New carb or rebuild??????????
Old Jul 29, 2006 | 08:43 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
Well i have to either rebuild mt carb or buy a new one..............
i have a 84 camaro 350 so the carb has a computer........
so im not sure what im lookin at such as which carbs im limited to .....im pretty sure i have to get one with a computer if i wanna smog it right?????????
so if someone could let me no what is better just buying a new one or paying some one to do a rebuild..............and suggestions which carbs am i limited two
Old Jul 30, 2006 | 01:28 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
no one?
Old Jul 30, 2006 | 01:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
might as well just rebuild the one you have. It's not rocket science. You ever built model cars as a kid? Yea, well this is pretty similar, just smells worse.
Aftermarket your choices are pretty slim. I think JET can build you one, but don't choke when you see the price.
Old Jul 31, 2006 | 12:48 AM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
is it hard to rebuild one!!!!!!
Old Jul 31, 2006 | 08:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
no, just keep track of all the little parts.
Old Jul 31, 2006 | 03:39 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I agree Rebuilding the one you have is best plus you get a great learning experience. Just have a very clean work area and lay the parts out so they are easy to keep track of. Also try to find a book or article on the web that gives step by step instructions on rebuilding your sytle of carb.
Old Aug 2, 2006 | 01:08 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
Am I Gonna Need Any special tools
Old Aug 2, 2006 | 04:15 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You'll need a dwell meter and maybe the idle mixture screw wrench. You can buy more tools but can usually get by without them. There's a recent thread on rebuilding the ccc-qjet, maybe under Nate86?
Old Aug 2, 2006 | 11:48 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
Yeah thnaks that was my next question for you guys is there any books or articles that i can buy or find to help me out along the way??????????????
Old Aug 3, 2006 | 12:25 AM
Sonix's Avatar
Car: 1982 Trans-Am
Rochester carbs - by Doug Roe
Rochester carbs - By haynes? or chilton?
Old Aug 3, 2006 | 01:10 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
roe's book is badass
highly reccommended if you are going to try to rebuild it
rebuild kit form napa are pretty good
some parts dont come in th kits, including a floatsome other partd
q jets are not complicated, wel they dont have a billion parts to fall out and losoem i have been inside of many, many q jets and some other carbs over the years
some i have successfully "rebuilt" and alot of them also just never run right regardless of what you do
to replace the throttle shaft bushings it best to have a press
i ahve never replaced any so far
if your throttle shaft bushings are sloppy worn enough then can allow manifold vacuum leakage
thats not good and canmake it run oddly
i bet a few ppl at any given moment have a problem with their car due to just this
and there is a very siple way to test for this leakage
hope any of this helps you at all,
you should use google and wikipedia.com to find out info too
:"D
Old Aug 8, 2006 | 08:45 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
thanks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
hotrod1988
Sep 11, 2015 04:39 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
