wut do i have 2 do to get rid of my qjet
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i have a 305 q jet carb and i took all the emissions off and o2 sensors (just installed headers)and i no my computers goin crazy and i was wondering wut i have 2 do 2 delete the computer and change it to a elderbrock or holley carb i no i have 2 get a vaccum advanced carb and distributor and i was wondering wut else i have 2 do. need help quick intake is cracked i got to get a new 1
Transmission: 4L80E/4L80E
Okay, let's get the dumb questions out of the way first.
Why don't you just put an O2 bung in the headers and put in an O2 sensor so the computer is happy again?
Car: 86' Trans am
they were shot and plus i took every peace of emmisions off any way and i want to get rid of the q jet and computer
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Guys have been ditching the q-jet since the 80's. How about a fresh idea and keep it? You can still use it without EGR, Air Pump, EFE...all that evil stuff you think robs power.
Car: 86' Trans am
also wuts the best intake carb combo
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
for a stock 305 you will want ot leave it stock intake and carb
really
the intake on it now is fine
you need ti find a qjet that is not computer controlled and also a distributor that is not computer controlled
then it will work
really
then it will work
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
is that even close to a good idea for you? Nope. What is a good idea for you? To leave it on. Sorry.
I've also never seen an aluminum intake crack... how'd that happen? My brothers composite intake on his crown vic exploded, and that's why I like all metal intake manifolds...
If your current intake needs to be replaced your cheapest route will be a junk yard replacement. For a new intake an edelbrock performer would work well with your setup, next step up would be a performer rpm or rpm air-gap. They'll breathe better up top but you may suffer some performance down low. If you plan on a cam change though, I'd go with the rpm air-gap. Just make sure you've got enough hood clearance first. It's taller than stock.
From Summit Racing - High Performance Car and Truck Parts | 800-230-3030 (since we got the dumb question out of the way):
Edelbrock EDL-2101 Performer intake, $114.88
Edelbrock EDL-1406 Performer carb, 600 cfm, electric choke, $264.95
Summit SUM-850001R HEI distributor, $94.95
TCI TCI-376600 torque converter lock-up kit, $76.88
Plus gaskets, shipping charges, etc.
