L88 base - how much drop?
Old Aug 14, 2006 | 06:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey guys, just a question...
Right now I have an open 14x3 air cleaner with a 1.25" dropped base on top of my Holley. Hood clearance with this is so tight right now that I can't even use a wingnut on my air cleaner stud anymore, I have to use a regular nut
Anyway, I keep hearing about the L88 air cleaner base being a propular choice for you guys with really tight fitting motors? How much of a drop does this base provide? Anything better than what I have now?
Old Aug 14, 2006 | 09:38 PM
Air_Adam's Avatar
Anyone?
Old Aug 15, 2006 | 02:04 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I am not using the L88 base but I am using a Pro Flow 14x3 cleaner with a 1 1/2 in drop on the base and I am able to use a wing nut on top with no problems.
Old Aug 15, 2006 | 08:40 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Adam come over today and try my drop base. I fit a 3" filter on my air gap. I use a bolt thought to hold it in rather than a stud and nut.
Trevor
Old Aug 15, 2006 | 12:14 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Switching to the GM "L-88" base from a typical generic Performance drop base like the Moroso base will get you about another inch of additional clearance.
On a holley you have to remove the choke horn and shorten the bowl vent stacks some. You may have to rework your throttle linkage bracket a bit. You can trim a Flat on the back of the base to clear a HEI cap too.
Here is the thread that has my pics showing the difference in base height Moroso VS GM L-88
Just measured the Moroso base. it is a 1.5" drop.
https://www.thirdgen.org/techbb2/sho...&highlight=L88
Old Aug 15, 2006 | 02:01 PM
Air_Adam's Avatar
Well, I have an RPM air gap now, with a VS 4160 Holley. It will be changed for a Holley 4150 (4777) whenever that gets here, and it could be modified if necessary. Why would the linkages need trimmed? This air cleaner was designed for the Holley carbs the factory used, no?
Old Aug 15, 2006 | 04:12 PM
Air_Adam's Avatar
Also... would the choke horn need removed completely? Or just shaved down some?
Old Aug 15, 2006 | 06:32 PM
Air_Adam's Avatar
Update.... found one at Year One. Its listed for a 1st Gen Camaro 302/396. They say "about 2in drop" incase anyone wanted to know.
Old Aug 15, 2006 | 08:06 PM
F-BIRD'88's Avatar
The throttle linkage is not the issue. The bracket is, mmay need to be lowered to clear the lower base.
The choke horn will need to be removed as the lid will sit that much closer to the top of the carb. The factory OEM carbs of the day had down leg boosters and a lower choke horn.
If you look at the pics in the thread you'll see.
The choke horns on Edelbrocks and Qjets are not as high as the aftermarket holleys are like your planned 4777.
Old Aug 15, 2006 | 11:03 PM
Air_Adam's Avatar
Ahh, ok gotcha.
85 Jimmy
Sep 30, 2015 07:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
RedLeader289
Sep 23, 2015 06:50 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
