86 t/a lg4 running rough
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Ok when I start my car (been sitting on and off for about 2 years) It stubles all over the place if i let my foot off the gas it will stumble and die. When you rev it up it chokes and i can here **** shooting from the carb. Until it warms up but even then it wont hold idle unless I adjust the idle to about 1100rpm. Any ideas? i just swapped this carb in from a 87 LG4 car. My previous carb would idle smooth in gear but would stall when put into any gear.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Probably need to adjust the carb to the motor. For ccc-qjet adjustment procedures see:
https://www.thirdgen.org/forums/carb...s-problem.html
Make sure when it's warmed up that the choke blades are fully open at 90 degrees. Plug all vaccuum lines at the carb while diagnosing to rule out vaccuum leaks.
