is this air filter to dangerous? and does this air filter catch on fire often?
Fast355
close
- Join DateJan 2005
- LocationHurst, Texas
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
- Axle/Gears14 bolt with 3.07 gears
- Liked:508 Times in 436 Posts
Another member just had his go up recently while working under the hood.
I had one a long time ago.... the foam melted and got burnt after only a few weeks.... this filter is a bad product. Flows no better than a K&N and looks retarded.
It didn't earn the name "triangle of death" for nothing.
those things are terrible,the foam breaks appart and drops into your carb.
I've had bad experiences too- stay away! One good backfire and you're in flames.
They are for show cars, for the reasons given. Even when they aren't flaming and melting, they don't breathe nearly as well as a factory dual snorkel or a 14x3 open air cleaner.
They work just fine IF you remove the foam. Then remove the metal screen. Then remove the lower part of the housing. Then replace it with a 14x3 drop base open-element air cleaner.
Quote:
Originally Posted by Damon
They work just fine IF you remove the foam. Then remove the metal screen. Then remove the lower part of the housing. Then replace it with a 14x3 drop base open-element air cleaner. lol true. I had one of these, HORRIBLE! Foam Breaks apart, catches on fire, clogs carb. Horrible Product
