best carb for 305
Old Oct 26, 2006 | 04:16 PM
bilyrocker33's Avatar
Car: 1985 Sport Coupe Camaro
Engine: 305 4 Barrel
Transmission: Stock
Axle/Gears: Stock
best carb for 305
what is the best carb for a 1985 camaro 305 (4-barrel) and manifold, if possible?
Old Oct 26, 2006 | 04:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
CC Qjet from the factory
Old Oct 26, 2006 | 04:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You could argue that the Edelbrock Performer (or GMPP q-jet manifold like comes on the ZZ4) or Weiand Action + are a step up over the factory manifold. But, until you do a lot of other things to the 305, it really isn't needed.
Exhaust, air cleaner (LG4, anyway), cam, heads, intake, carb - that's the performance modification order, and the carb should only be considered for replacement on off-road applications or manual transmission vehicles.
Old Oct 27, 2006 | 01:00 PM
jessed's Avatar
Car: 1986 Trans Am
Engine: 305 LG4
Transmission: 5 spd
Would you say the Weiand Action+ and Edelbroc Performer are on par with each other? Should one be taken over the other for a particular carb setup? (Such as Weiand w/ Holley carb or Performer w/ Edelbrock carb?)
Old Oct 27, 2006 | 02:15 PM
davjr1985's Avatar
Car: 1985 sport coupe
Engine: LG4
Axle/Gears: 3.08 open
What all is it going to take to make a carb change from a stock carb anyway. I've been told that if i take off my stock q-jet i will have to change my distributor as well as intake manifold. I am having a little trouble tuning this stock q-jet should i spend money to fix it or just go with a whole new setup.
Old Oct 27, 2006 | 03:26 PM
five7kid's Avatar
They're basically equivalent. Chose one, I'd tend toward the Weiand, personally, but either one should be fine. Doesn't matter which carb, either manifold would work similarly with either carb.
Off the thread topic, but you've heard right.
What you should do depends upon what the problem is, but it's hard to beat the stock computer-command q-jet for street performance.
pimp2303
Jul 27, 2017 02:03 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
