TPI To Carb Cable Questions
Car: 86 Corvette
Transmission: 700
Axle/Gears: 3:73 Z51
O.K. Ive been lurking on this site for a while and the info and people are Great...Yes I don't have an F body although Ive owned several..The snobs in the forums for my car look down on converting and the info is scarce....So which that being said a TPI L98 is a L98 and my question is I'm Almost done but the cables look too long..ie acel,TV,Cruise..How did you guys route them?? I have the correct bracket that will go to the back of the manifold..But they just look too long..I could route the under the wiper motor ???Buy shorter Cables??( I don't think I have To)but I want to do it right...Thanks
86 L98,Eagle crank,rods,10:5 Pistons,Melling cam,Crane 6:1 RR Edelbrock 1406,Edel Performer Mani....The list goes On and On
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i just did a tpi-carb swap on an l98. needed new tv and throttle cables. not cruise, but probably same deal. easier for me though cause i just got cables from a carb third gen. im not sure what would work for yours.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
When I did mine, I got the TV geometry corrector bracket, and a spectre adjustable bracket from summitracing.com
SPE-2428 - Bracket
SUM-700203 - Geometry Corrector Bracket
I just wound the cables around so that they curled one time and put them through the bracket. You are going to have to flip the one L shaped bracket to get it to reach far enough. This combo is probably the cheapest way to do it and still have the tranny work properly and get full cable travel.
You are also going to need Mr Gasket part number 1512 if you have the throttle cable with the small cylindrical piece of steel on the end of it. That will make it so you can slip the cylinder thru and secure it.
SPE-2428 - Bracket
Car: 86 Corvette
Transmission: 700
Thanks So Much for all your Help..I was hopeing I could do that..Should get her running today
Anymore do's or don'ts you guys can think of let me know
That's going in you're vette? Did you check hood clearance with the air cleaner yet? It's gonna be even more tight for you since the vette hoods sit lower. I tried a 14x3 on my Iroc and that was too tall so I got a 2 inch element with a standard base and it juuuuust touches the hood when I close it. (this is with the liner removed too). You are probably gonna need a drop base with a 2" element and a flat lid (Mr. Gasket, although I hate them, makes one).
just make sure you reset the tv cable when all is said and done. make sure the fuel pump and fans are still running off the computer (unless you removed the ecu and put some other kinda setup in there). i had that problem without knowing why and had to put the ecu back in.
Car: 86 Corvette
Transmission: 700
Thanks Again..I was afraid since I had a "Foreign Car" I wouldnt get a Responce...You guys are Great!!! Yeah I checked and double checked clearence and the hood closes with and inch to spare with a drop base a/c....Also I will leave the ECU in for a while the 86 has a lot of things it runs besides that crazy TPI..so I believe my fuel pump and fans will still run..The ECU is chipped so I hope some of the none ECU stuff will work ie fan temp shift series..Also I have a 4th gear lock up for the trans..just have to install it..I learned most of this from this site.....I'll show pics when done
i still never did lockup on mine. unless the computer is still doing it. it isnt bad though.
since july i believe. mostly long highway trips too. no problems in OD the whole time. havent put the geometry correction bracket on yet either. (it flew out from under my hood)
Sanjay
Aug 12, 2015 03:41 PM
