Pre 87 Intake on 87 and up
Old Feb 10, 2007 | 02:24 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
What needs to be done to the intake to bolt it right up? I thought that I remember reading that you have to elongate a few holes.
Bill
Old Feb 10, 2007 | 02:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well if youre wanting carb on a FI engine then you can just get a carb intake off an 87 or 88 caprice impala firebird camaro
stock factory
but yes the 4 middle holes changed angle for 87
Old Feb 10, 2007 | 02:30 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Easy to do. Just takes alittle time.
Old Feb 10, 2007 | 08:40 PM
Can you give me some guidance on this?
Old Feb 11, 2007 | 01:51 AM
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
there is a kit on summit that may make it easier...it has the angled inserts and bolts for ease of installation.
Old Feb 11, 2007 | 02:04 AM
cool. Do you have a part number
Old Feb 11, 2007 | 02:11 AM
http://store.summitracing.com/partde...8&autoview=sku
Is the kit that you are talking about? It says holley. Will it work with an Edelbrock intake? Just wondering if you knew. Thanks
Bill
Old Feb 11, 2007 | 02:18 AM
pmpnavt's Avatar
Engine: L98 350
HLY-90748
is what i used
i have no idea if it will work...i dont see why it wouldnt but i am not an expert on this. i used the kit with a holley intake.
Old Feb 11, 2007 | 11:15 AM
Hey did you have to do any drilling?
Old Feb 11, 2007 | 04:13 PM
pmpnavt's Avatar
Engine: L98 350
minor machining, i wish that i would have just oval'd the holes instead of cutting the intake clike they suggested in the instructions. but the intake torqued just fine and it sealed great. it was actually much easier to install this intake than the tpi one. because the bolts mount at, lets say, a 45 degree angle on the older intakes, you would just need to expand the holes to make a bolt go through them at a more straight up and down angle. just holding the bolts above the intake, at the right angle, you can tell how much metal needs to be removed. it wasnt that much at all
the hardest part was just holding the intake because i didnt want to scratch it up
Old Feb 11, 2007 | 06:39 PM
oh ok cool. thanks.
Old Feb 11, 2007 | 06:42 PM
pmpnavt's Avatar
Engine: L98 350
gl with it
Old Feb 11, 2007 | 07:21 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
Would modifying the 4 center holes cause any type of leaks?
Old Feb 12, 2007 | 12:43 AM
got any pics of the what the work looks like
Old Feb 12, 2007 | 01:20 PM
birdsgonnafly's Avatar
Car: 87 T/A
Engine: none right now
Transmission: prob th350
this is a simple one take your drill and bit 9/16 or one size up dont remember start by drilling the hole at the normal angle back it out increase angle and repeat it will be mildly thin on the outside edge ive even seen it break dont worry thats what washers are for
Old Feb 12, 2007 | 07:53 PM
Nice. Thanks for the diagram. Looks good
Bill
Old Feb 12, 2007 | 08:48 PM
Car: 87 T/A
thanks hope everything goes good
Old Feb 12, 2007 | 09:56 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Not if done remotely right.
Old Feb 14, 2007 | 01:48 PM
You guys should make this a sticky. I bet this come up a lot.
Thanks for the help
Bill
Bubbajones_ya
Jul 6, 2024 08:32 PM
6speedIROC
16
Mar 15, 2023 08:33 PM
customblackbird
Oct 1, 2015 04:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
