Carb help.
Old Feb 23, 2007 | 09:20 PM
Benck's Avatar
Car: 1991 Pontiac Firebird
Engine: v8 305 "For now"
Carb help.
What do you turn the jets at for peak performance for a 750 edlbrock performer series?
Old Feb 23, 2007 | 10:36 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
There's no way to tell where you should "turn" the jets. Every motor is different, and you'll have to test different combinations of jets and metering rods to get the most desired setting. The easiest way to do this is to get a dyno tune, but if you want to be able to tune yourself, look into getting an A/F ratio monitor.
There is no "turning" of the jets to change performance either. You have to buy a calibration kit with different sized jets and metering rods and try different combinations.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
customblackbird
Oct 1, 2015 04:30 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
