pics on where to mount 3 port regulator
Old Feb 9, 2007 | 07:24 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
im using the stock tpi lines trying to find were to mount the regulator anybody got a idea or pics?
Old Feb 9, 2007 | 09:05 AM
Damon's Avatar
When I converted to carb I mounted the regulator on the driver's side strut tower. Then I hooked everything up with flexible lines and parts store brass fittings.
Old Feb 10, 2007 | 05:03 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
my friends is also on his strut tower drivers side. heres mine.
if you get a gauge also, which you should, mount it as close to the carb as possible.
Old Feb 11, 2007 | 02:04 AM
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
i put mine on the drivers side like zz4 86 z28 's friend did. i took this pic last year, this is the best pic i have right now with the regulator in it.
Old Feb 11, 2007 | 08:50 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
maybe a bit close to the headers...
Old Feb 11, 2007 | 11:13 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
found this pic awhile ago, this is how i did mine..
Old Feb 11, 2007 | 04:15 PM
pmpnavt's Avatar
Engine: L98 350
ooh very nice
Old Feb 23, 2007 | 11:39 PM
d1rtyb1rd5252's Avatar
Car: 1984 Trans Am T-tops
Engine: Chev. 350 bored .030 (355)
Transmission: GM T-5 5-speed
Axle/Gears: Stock 10bolt 3.55
I got mine on the passenger fender then to a cooler and then to tha carb.
Vintageracer
Jan 10, 2020 05:33 PM
evan555222
Sep 20, 2016 02:51 AM
evan555222
Aug 22, 2015 07:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
89-S-dime
Aug 12, 2015 11:57 AM
