car almost stalls on turns or quick stops
Old Mar 8, 2007 | 02:38 PM
HaIrLeSsHoBo's Avatar
Car: 86' Trans-Am (wrecked)
Engine: none currently
Transmission: Borg-Warner T-5
Axle/Gears: 2.86:1 w/ one broken axle
I have a 350 with an edelbrock 600CFM carb and electric choke. I am running points-style ignition with vacuum advance and an initial advance of 8*. If I make quick, complete stop the car will drop to 100-200 rpm and sometimes shut off. If I make a turn without my foot on the gas (coasting on a turn) it will do the same, and also if I do a U-turn and then try to accelerate fairly heavily (not wot) it runs really rough, almost as if I had a couple fouled plugs. I can accelerate heavily from a stop and 7/10 times it will run fine, but every couple times it will act as if it were skipping. I thought it might be my fuel pump (which I had determined was not pumping correctly), so I changed it and it helped a little but did not solve it by any means. Any ideas what this could be? it is driving me crazy.
thanks in advance.
Old Mar 8, 2007 | 02:56 PM
kevfromphilly's Avatar
hey man did u put a fuel pressure regulator on that thing i switched mine out and the stock fuel pump puts out like 28lbs of pressure and my holly was supposed to work off 7 lbs i dont know if your running out of gas or getting too much, but why do u have your initial advance set at 8?
Old Mar 8, 2007 | 03:22 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
With the edelbrock carbs, sometimes the engine will stall if the floats are not set properly. Another thing to try would be installing the spring loaded needles and seats- they are supposidly for off-road applications, but if you want to do doughnuts, carbs flood way too easily without these. Another question: have you tuned the carb properly? Does it hesitate when you are in neutral and you floor it quickly? You might have to adjust your power valve down a bit, or change out the rod springs.
On the fuel pump- unless the pump is a high pressure or electric pump, you should not need a regulator. The stock mechanical pump only puts out a max of 12 PSI under optimal conditions, if that. It has plenty of flow for a 1406, the only reason I could see switching to an aftermarket pump is reliability in your case. The fuel pressure is not likely the cause, but if it was, the needle trick will still help. Hope this helps,
Old Mar 8, 2007 | 09:37 PM
It is a mechanical pump from napa, so I am sure that it isn't putting more than about 5 or 6. By the way, my carb is a 1405. I haven't had the money to buy a 1405 tuning kit yet, but I do plan to within the next week or so. As for the floats, that was exactly what my dad said it probably was so I plan to check those tomorrow. Thanks for the quick replies.
Old Mar 9, 2007 | 12:09 AM
Car: '84 Berlinetta
Engine: ZZ4
1405 is the same as the 1406, just without an electric choke and .001 larger jets. Like I said, get the spring loaded needle and seat set, PN EDL-1465. This will prevent the bowls from flooding during a hard stop or sharp turns. The floats should be adjusted to 15/16" at full drop (when the housing is right side up) and 7/16" topped out (with the housing upside down).
Old Mar 9, 2007 | 03:16 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i used to run a 1405, and i'd set the floats to the above mentioned specs. had the same stalling problem too; cleared right up after the float adjustments berlinetta describes.
the fancy N/S won't hurt either, but set your floats first!
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
