Carter AFB Stumbling when turning
Old Apr 6, 2007 | 10:41 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
I have a Carter AFB 750 (Same as an Edlebrock) with electric choke and it has recently been rebuilt. Well before and after rebuild, if you would come around a sharp corner or stop quickly, it would stumble for a moment and then come back to idle. If you give it a little throttle it dosn't do it near as bad but if you are idling it does it to the point that it almost dies. I set the floats when i rebuilt it to 7/16 as the guide says. Well then i thought they might be to low so i set them to 3/8 and now it still does it if not a little worse. Do yall think that they are set to high, or know of a solution to my problem.
Old Apr 7, 2007 | 12:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carter AFB Stumbling when turning
Try setting them lower.
Old Apr 7, 2007 | 03:35 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Yea im going to try that today but i was wondering if anyone has had the same prob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
makaveli09
Sep 15, 2015 10:43 AM
