Third fuel line
Old Oct 6, 2007 | 01:36 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Third fuel line
Working on finishing my fuel system this weekend. Im running a fuel cell and I already got the old tank out and everything. Im looking at the fuel line shtta go to the front but im confused. Theres the three lines, i know the thick one if for fuel delivery and the thinner one is for fuel return but then theres a third one. I remmeber unhooking it from the fuel pump a fe months ago but whats the third line for? can I just plug it up or what? I can post a pic if needed, lmk
Thanks Guys
Old Oct 6, 2007 | 03:03 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Re: Third fuel line
Pretty sure it goes to the charcoal canister where the gas fumes are stored. The fumes are then burnt when you are driving down the road.
I plugged mine off to removed the canister from the engine bay to clean things up. Had to install a vented gas cap also.
Old Oct 6, 2007 | 03:04 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Third fuel line
Alright if thats the case then ill plug it up since i pulled all that junk out
Old Oct 7, 2007 | 01:02 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Third fuel line
One more question. I bought a used external fuel pump from a guy on these forums. Do I need to prime it a bit b4 I try runnig it or what?
Old Oct 7, 2007 | 01:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Typically not.
Old Oct 7, 2007 | 02:09 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Third fuel line
Cool, thanks for the quick response also, wanna get this done!
Old Oct 7, 2007 | 05:56 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Re: Third fuel line
I would mount the pump so it is below the tank as much as possible(gravity fed) and install a filter between the tank and the pump so you don't damage the pump.
Old Oct 7, 2007 | 06:44 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Third fuel line
Hum got the filter in that spot but the pump is about 4 inches higher than the cell
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
