do I need new jets?
Old Oct 27, 2007 | 12:18 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
do I need new jets?
Here's what I'm gonna be running:
270/270 470/470 hyd flat tappet cam
1.6 Rocker Arms
305 bored .030 over
I picked up an older mechanical q-jet at a swap meet for like $25, planning on rebuilding it ($35). I know SBCs will run just fine with one because thats what they came with, but if i'm going to be pushing 325 horsepower, do I need to put bigger jets in?
Old Oct 27, 2007 | 12:27 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: do I need new jets?
I doubt that motor will be putting out 325 horsepower, but good luck. Jetting will be determined when you get the motor running and pull plugs.
Old Oct 27, 2007 | 12:31 PM
Car: '84 Camaro SC
well I only put the parts in there pertinent to how much fuel/air would actually be going into the cylinders, the only stock parts on this motor are really the connecting rods...
but thanks for the info. what exactly would I be looking for? wet plugs, fouled, etc?
Old Oct 27, 2007 | 03:47 PM
xpndbl3's Avatar
Car: 1984 Z28
google plug reading and check out the pictures, or holley tuning and look at the plug pictures
Old Oct 27, 2007 | 07:02 PM
Car: '84 Camaro SC
Sweet, thanks man.
Old Oct 27, 2007 | 08:01 PM
Damon's Avatar
What jets are in there stock?
72s are very common. On a hotted-up 350 or larger motor a bump of 4 jet sizes over stock on the primary side is often a reasonable starting point vs. the stock "emissions" calibration.
Often the idle circuits will be too lean as well with a wilder cam. That's easy to fix, too, but changes are irreversible so you must be careful and go in small increments. I'm NOT talking about jsut adjusting the idle mixture screws here.
Old Oct 28, 2007 | 12:54 PM
Car: '84 Camaro SC
I have no idea. I just yesterday looked up the serial. It's from 1976 and off a Chevy originally, and California-Emissions legal (not sure if that's good or bad).
Mine's a hotted-up 305 though, would that four-jet jump still be advisable?
Old Oct 29, 2007 | 12:58 PM
Damon's Avatar
Depends on the starting point as much as anything. Certainly you can't hardly every go far wrong going up at least 2, assuming the jetting in it is stock right now.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
69GTOby
Apr 18, 2016 02:34 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
mackjar66
Sep 14, 2015 01:17 PM
