Fuel pump recomendations?
Old Oct 30, 2007 | 10:29 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Hey guys, Is there any intank fuel pump that will fit my application? I will be converting to solid roller in the spring. Right now I am using the stock TBI pump w/ return style regulator and it seems to be losing pressure. FBird88 gave me a lot of good advice but the external electric pumps seem loud / a pain in the neck. Is there any intank pump, walbro, holley, etc. that will work?
Let me know.
Old Oct 30, 2007 | 01:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Fuel pump recomendations?
Factory replacement for TPI application perhaps? You're using a regulator at the engine right?
Old Oct 30, 2007 | 01:24 PM
Car: 91 Firebird
Engine: Turbo 355
I've been eyeing up the Walbro 255 lph pump. I just need to find out, or find a link were I can get one.
Old Oct 30, 2007 | 01:25 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
walbro 255 i imagine would be fine, although I like the sumped gas tanks with external pumps, so to each their own.
Old Oct 30, 2007 | 01:27 PM
Car: 91 Firebird
Engine: Turbo 355
I was looking into a Holley Blue pump, but I've heard some bad things about them. Where do you suggest I pick up a Walbro? Would I need the installation kit, or could I re-use my existing hardware? The car has NO rust.
Old Oct 30, 2007 | 01:31 PM
xpndbl3's Avatar
Car: 1984 Z28
no idea on installation kits on those walbro 255 pumps other than my buddies have put a few in their cars. A holley blue, is alright for a mild combo, but some last for years and some fail within months. It is a loud pump which is kinda a drawback.
Old Oct 30, 2007 | 01:39 PM
Car: 91 Firebird
Engine: Turbo 355
Thats what I've heard as well. I might as well get the pump and all the necessary accessories in the install Kit. I think I may have found one. Let me know what you think.
http://www.erzperformance.com/produc...rebirdpump.htm
Old Oct 30, 2007 | 02:02 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
cost more to do but the Holley HP pumps are good. but then you do need the sump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
