need help on rebuilding my non-cc q-jet
While disassembling and following a rebuild guide I noticed that the APT(adjustable part throttle) device was not inside the fuel bowl. My carb has the bulge and cavity to house it but I don't know if it should be there or not. I decided on a rebuild because of a rich condition I couldn't pinpoint. Also concerned that the power piston spring is too stiff for my cam. Would any of these contribute to my rich mixture. ...One more thing, my rebuild guide showed both a front and rear power piston. Something is definately in the front bore , but it will not pull out like the rear piston did. It looks like a small shaft with a shape that resembles my idle mixture screw ends. It will twist, but not pull out. Sorry to throw so many questions together..any advice appreciated
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: need help on rebuilding my non-cc q-jet
Got a digital camera? Take some pics.
I'll see if I can find my old pictures tonight when I get home.
Aneroid cavity is not needed, if that's one of your questions.
You're right, if you've upgraded your cam and have less vacuum, you'll want a weaker power piston spring. You can buy a pack of 4 from Edelbrock. I used an old Q-jet body as a testing tool to figure out how much vacuum I have at idle, vs other conditions, then how much vacuum it takes to pull the piston down against all the springs I had. Then I picked the right spring.
- That's your "lean stop". I think it may also be called the adjustable part throttle, not sure on some of the terminology sometimes. You can loosen that until it comes out, but under high vacuum (idle, low load) your vacuum should pull the power piston down until it hits that lean stop. You should have the height set such that it pulls the power piston (and rods) into the jets just at the size of the stamped size - ie to the .043" part on a 43K rod. When there's no vacuum it'll always pop up to the same area, the .026" power tip. If you have the lean stop too far down it'll let the rod go into the jet 'till where it's .060" thick or so, and you'll be ultra lean. If it's too high then you'll always be on the power circuit - rich.
Set the height of that using a caliper, and the power piston and rods in hand. Get a set of power piston springs and try those. Get some pictures and MSpaint if you want some more help.
I'll see if I can find my pictures tonight, or do a search on here under my name on the carb board and look at any pictures i've posted before.
thanks a bunch, I think you have some good answers to what I'm lookin for. I understand the function of the lean stop now. On the powerpiston, does the plastic collar get pushed down into the bore on reassembly, and how far?
Also I noticed that the carb had #72 primary jets installed. Is that too much for my 305 ? Motor has 180cc vortec heads and comp 268 cam with .454 lift.
Car: 1982 Trans-Am
Push it down until it stops, or until it's flush with the bore.
jets depend on air bleeds, it's hard for me to say what jets are right for you. Trial and error.
That should be a good running engine. Compression isn't too low with vortecs on a 305?
thanks again for the info.... I had the heads milled .040" so they should cc 60-58. Hope to get this carb back together this weekend. The problem I am having is from a cold start up. . I give it a full choke, setting the throttle blade closed. It starts , acts like it wants to run then dies. If I prop the blade open a bit and give it another pump then it starts, but runs rough till it begins to warm up. Also when warm and running there is no affect when adjusting any of the idle or throttle screws. So I'm thinking that fuel was seeping in from some source because I checked my plugs and they were sooty. Thats why I started a rebuild plus the fact I knew no history of the carb. Did not realize that there was only a handful of parts to this besides screws. Can't say I noticed anything cloged or leaking either. Any ideas on my start up problem?
Forgot to mention, the choke break or pull off is working
Car: 1982 Trans-Am
Good eyes 57.
After it's all put back together right (make sure lean stop is right, power piston arms are ABOVE gasket, etc. Then you can set your choke.
- Choke pulloff doesn't leak, holds indefinately?
If so, set it up as per spec. I think i've posted how to set your choke a handful of times, try to search and find it, I don't really want to type it out again.
Good eyes 57.
one more thing..it's been he'll getting my fuel lines to seal at the carb. I'm using the factory line and fuel filter fitting too. Found a gasket for the filter holder in the kit. That helped, but the flared fitting has brought me near insanity. I used a freaking pipe wrench on it and there might still be slight seepage. It all sealed with little effort on my old cc q-jet!! Will get some pics up soon ...
Car: 1982 Trans-Am
Yea, make sure the little white gasket is on the end of the "nut" that goes into the carb to hold in the fuel filter. Then yea, you have to tighten the crap out of it or it'll seep
Transmission: 4L80E/4L80E
You shouldn't have to tighten the crap out of the fuel line fittings. If a nice snug tightening doesn't seal it, you've got a problem with the sealing surfaces that should be addressed. Overtightening the fittings is a sure road to future expense.
The hard vacuum line I'm still uncertain, It ducks down the firewall some where. Thought it was my prob on stalling when it shifted to Drive. I richened up my idle mixture screws and that helped some what with the stalling. Drove my T/A for the first time yesyterday and it justs sucks. Ran better on the computer. After the drive I noticed my plugs had very clean insulators with blackened electrodes. Is it possible I have too much air flow for my jetting. Now my damm alternator might be bad. the voltage needle on my gauge goes crazy from 8 to 20 and back.
A straight mill of .040" is bound to require milling the intake.
yes, got that one to seal with the new gasket and heavy wrencing thanks
The gasket face mismatch between the heads and intake when the heads have been shaved but the intake hasn't can cause an air leak into the cylinders. You're likely to suck oil in as well, which would not lead to white plugs.
appreciate the replys...Took the carb apart again. I'm going to try some of the online Q-jet performance tips. What kills me is that in Park it revs like a superstock. Once it warms up that is. I was told to look at my ignition for the source, but I can't imagine the poor performance being there. I have a brand new Mallory hei dist. with an Accel Brute Force coil on top. I gapped autolite #103 platinums at .050". Should I pull a plug ,ground it and crank it over to do a visual or is that method useless? Also will the trans feel real slushy when the motor is no longer on the ecm or is that just from the lean engine condition?
Car: 1982 Trans-Am
ooh. Not sure about the accel or mallory parts, but aftermarket ignition parts can sometimes cause really strange ghost problems. First off, ditch the platinum plugs, those are for minivans. Then go back to a .040" gap.
Yes, you can pull a plug and crank it over for the visual. That'll only tell you if that plus is sparking. I really think your problem is more carb than ignition since you just rebuilt the carb.
What car is this? Year? Tranny? I'm not sure how auto trannys work with cc/non-cc carbs. I think you do need to fix the lockup part, but again, that depends on year.
If it runs well after it's warmed up, then it's the choke/choke system. Ignition and other carb problems don't disappear when warm - except for choke problems. (some rare exceptions.)
Sonix, Took another stab at the carb. Completely tore it apart again except for the needle and seat,checkball,retainer ,etc. Took a .090 drill and opened up the idle discharge ports, then I took a .078 drill and open up the primary jets to accomodate my .050 metering rods. Put the carb back together and on the car. Got an immediate start up this time, adjusted my idle mixture and curb idle. Took it out for a spin and finally felt some decent power. But I still have the alt/voltmeter going crazy and the dash/interior lights surging very brightly. thanks for your help
Car: 1982 Trans-Am
D'ah! Drilling jets is a big no no! But hey, I can't argue results eh? Sounds like it works, so power to you!
Most articles I read insisted the jets and rods have a .025 - .030 variance. for a mild cam so I thought why not. I drilled them out about .005. Other things, I'm gettin a spike in my voltage reading at the battery when my car is running only. Any ideas?
Car: 1982 Trans-Am
Yea, you'll want the jets that much bigger than the rods, but the jets have a special orifice taper on them, if you drill it you ruin it. That's just what i've read, thinking about it I don't really believe it to be true. (You have .030" of taper at a constant angle, you drill open another .005", the taper doesn't change...)
Anyway...
You probably have a voltage regulator going bad on your alt. Ie, the alt is dying. I'd just recommend a new alt. I highly recommend picking up a CS-144 (if you wanted my opinion).
I paid $50 for mine at a JY, and it took about 10 minutes to modify it, and the bracket for it to fit in my car. 130A now, with rock solid reliability. Do a search in the electronics board for my thread about that, if you're interested.
Anyway...
Kinda figured that on the alt. Just removed it and going to take it in for a check. Switching to a standard hei fom a comp.contolled hei had me concerned about the electric spikes. You and 57 been a big help on this one. hope to get this kinda feedback in the future, good day
3.8TransAM
Sep 27, 2015 08:37 PM
