gas coming up thru carb into air cleaner
ok. this is my situation, and i would appreciate any help. my 86 camaro, with a computer contolled q-jet starts cutting out at very high rpms (for instance, when i floor it, and it is at peak rpm before it hits 2nd, or getting onto the highway when i hammer it and i hit peak rpm right before it hits 3rd). then i take the lid off my air cleaner, and its covered in gas. there is a puddle of gas laying in the base of my air cleaner. today was the first day i have noticed the gas, but the past 3 weeks it has been cutting out at high rpm. scares the **** outta me when i am merging onto the highway and then my car starts to quit...
any ideas? i checked out the check engine light the other day, code 53 egr valve, so i replaced it. didnt help this problem at all.
here is a pic of my air cleaner set up
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: gas coming up thru carb into air cleaner
why are you running that round air filter instead of the factory filter inside the air cleaner itself?
my stock round air filter got all covered in gas when the gas flies outta the carb, so i cut that 90 degree bend off of a cavalier intake i had laying around, and the new filter set up doesnt get saturated with fuel
Car: 1984 Z28
have you adjusted the floats to see if the secondaries are stuck? checked fuel pressure? etc
Car: 1984 Z28
go get a chilton's manual and check what i've mentioned, should be under $20. Floats stuck will cause fuel to squirt out of the vent tube, and too high of fuel pressure could cause the same, fuel to squirt out.
Transmission: 4L80E/4L80E
The E4ME sticky in the top section of this forum has the information about the float and needle & seat.
Do you get gas in the air cleaner under any type of driving, or only WOT?
well my cousin said my fuel pump might be going, when i bout the car this time of year in 2005. it sometimes hesitates. so dillon, when the pump is going out, it can cause irregular fuel spray from the carb?
i cant say for sure but when i bought mine with the q jet and 305 it would hesitate and stutter at wot. i didnt know what to do so i drove it for a month then it wouldnt start. if i tried to start it with the air cleaer off and hood up i could see it blowing gas up out. i later found that the fuel pump was bad. i never fixed it though so i dont know if that will fix your problem. i swaped motor, carb, trans, and went to mechanical fuel pump. i cant say for sure that the fuel pump caused my carb to spray gas and stutter but i suspect that was the problem. hope this helps, good luck. post up when you figure it out , im curious
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
