HELP PLEASE ON RECCOMENDATIONS
Old Dec 21, 2007 | 08:54 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
I Have been talking to a few people on helping me choose the right intake for my car. i right now have an 91 rs with stock 305. my plans are headers,exhaust lt1 cam, and go from tbi to carb. i am stuck on what manifold to chiooose. can u guys point me in the right direction.
some are saying this manifold wieand X-cellerator and some are saying the edelbrock rpm. what should i go for? please help me
Old Dec 21, 2007 | 09:29 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: HELP PLEASE ON RECCOMENDATIONS
performer rpm air gap
Old Dec 21, 2007 | 10:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I like the plain performer RPM, but the air gap works well too. Check hood clearance and whatnot.
Don't bother with the straight performer, that won't get you anywhere.
Old Dec 21, 2007 | 10:12 PM
Car: 88 IROC-z
Engine: LO3 V8 305
why should i not get the weiand x-cellerator???? and why go with the performer?
Old Dec 21, 2007 | 10:14 PM
xpndbl3's Avatar
Car: 1984 Z28
i personally like the edelbrock manifolds, the performer rpm and rpm air-gap are both proven intakes thus why i'd recommending them. The air-gap is an even more updated design and "should" fit under a stock hood.
Old Dec 21, 2007 | 10:19 PM
Car: 88 IROC-z
Engine: LO3 V8 305
do u know anything aboiut the wieands? or the exellerator?
Old Dec 21, 2007 | 10:21 PM
xpndbl3's Avatar
Car: 1984 Z28
yea i know they've been around for 25 years probably unchanged and no one local that races uses them compared to edelbrock, I recommended you an intake, you are set on the other one, so take that for what it's worth.
Old Dec 22, 2007 | 02:00 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The accelorator is a single plane manifold. You do not want any single plane manifold. It is a mismatch to your planed other mods.
A dual plane hi rise type manifold is the best choice for you.
Wieand and Holley have many to choose from. eg Holley #100-36
www.holley.com
www.professional-products.com
http://www.holley.com/index.asp?division=Weiand
eg Weiand action+plus #8120
Any of the dual plane manifolds wil make more power than a single plane manifold will in the rpm range you will be using with your 305.
Old Dec 22, 2007 | 03:56 PM
Car: 88 IROC-z
Engine: LO3 V8 305
what is the part # for the edelbrock rpm?
Old Dec 22, 2007 | 06:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
7101 IIRC for the square bore, 7104 for the Q-jet style. That's for non-vortec pre 1987 style though.
Look it up on summit, this isn't nearly as hard as it sounds.
Old Dec 23, 2007 | 02:39 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Why are yall giving him manifolds for PRE 86 heads? He told yall he has a 91.
Old Dec 23, 2007 | 02:47 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Those manifolds will work on 86 and up heads. Just not the vortec heads. Vortec heads have the vertical bolts.
Go with an Air Gap. In fact, you could probably use the "crosswind" which is the knock off of the air gap. It's cheaper.
Old Dec 23, 2007 | 02:51 PM
Car: 88 IROC-z
Engine: LO3 V8 305
why do i not want a single plane manifold? and why is the performer soo much better then the weiand?
Old Dec 23, 2007 | 02:55 PM
racer J's Avatar
Engine: 305 TBI
No, no they will not. Look at their site. Every 8120 manifold listed is for pre 87 heads.
Old Dec 23, 2007 | 02:59 PM
Car: 88 IROC-z
Engine: LO3 V8 305
http://store.summitracing.com/partde...6&autoview=sku
that is the manifold that people have told me to get. what is wrong with that? they say it will give me more power then the performer
Old Dec 23, 2007 | 04:11 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Looks like a great manifold for an aggresive cam, oval track, and a 7 grand rev limit. What size cam will you be using? Have you considered what cam works well in a 305? BTW What are your intentions for your car? Is that really the right manifold for a 305? I'm looking for an intake too.
Old Dec 23, 2007 | 04:14 PM
Car: 88 IROC-z
Engine: LO3 V8 305
Why do u say this intake is for OVAL TRACK? i would think its for street/strip no?
i wanna do ultimate tbi mods, 3" catback exhaust, headers, lt1 cam. and sum new rear end gears. i have msd ignition box, wires and distributor coming, i have spec stage 2 clutch kit, and 19lb flywheel coming, and underpulley set. Taking out the smog pump and mb delete the a./c those are my mods soo far that im gunna do. so does that intake sound like the 1 for me?
Old Dec 23, 2007 | 04:19 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
I would listen to xpndbl3 and sonix they both know what they are talking about. Single planes will be a big let down on a basically stock 305 maybe with a .550 lift cam and a power adder and forged internals and lightweight valvetrain components you Might be happy with that intake. The Edelbrock Air Gap stuff is a preference for alot of engine builders and the professional products crosswinds as mentioned are also good (not as good in my opinion)
you want to utilize your mid range rpm. unless it will basically be a strip car which in that case you better get a better motor that a stock compression 305.
Old Dec 23, 2007 | 04:25 PM
Car: 88 IROC-z
Engine: LO3 V8 305
thanx js for the info. just soo confused on this bs
Old Dec 23, 2007 | 04:26 PM
jstoltz's Avatar
no problem. just my
Old Dec 23, 2007 | 04:33 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Well, Have you red the description in the Summit link you provided? Says "Oval track"
Old Dec 23, 2007 | 06:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
I wouldn't lose sleep over what they say the usage is, that's more as a reference for RPM. Match the RPM, and how "good" the manifold is. Ie, a Torquer 2 might say it's right for your RPM usage, but it's a POS... The quality is something we can advise on.
Anyway, the amount you save by using a professional products manifold isn't really worth it. Do a search, some members have posted pictures on the quality. The ports aren't a consistent size, etc etc. For maybe $20? bah, skip a few big macs and you're there
On second thought, (after re-reading this thread more carefully)...
-mildly modified 305 TBI engine
-wants to go carbed
-sticking with TBI heads
Basic performer might be your best bet. You'll never get over 5000RPM in a 305 with TBI heads eh?
Old Dec 23, 2007 | 07:19 PM
Engine: 400
Old Dec 23, 2007 | 08:14 PM
Car: 88 IROC-z
Engine: LO3 V8 305
sonix thanx for the info and all your help, i will guess be going with the performer. do you think u can tell me a model # performer fromm summit to get, there are a few to choose from and i dunno what to get.
http://store.summitracing.com/partde...4&autoview=sku is this rite?
http://store.summitracing.com/partde...4&autoview=sku or this?
Old Dec 23, 2007 | 08:35 PM
xpndbl3's Avatar
Car: 1984 Z28
don't listen to sonix....he means well but his info is not correct. Performer rpm is the one you want, not the basic performer, it will make on average 10hp more at least even at low rpms over the basic performer. go on summit and get the performer rpm for the 87-up style heads, which shouldn't be hard to find.
Old Dec 24, 2007 | 09:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
The two you listed - the more expensive one was the air gap one. If you think it's worth it, go for it.
xpndble - yea, if it was me, i'd use the RPM too, but I'd hate to hear him saying that his car feels lazier at the low RPM after the swap. I'm not sure anyone *really* loses anything in the low RPM, but just in case...
In 1987 or thereabouts they changed the angle of the center two intake manifold bolts, that's the reason they have pre 1986 and 1987 and post, intake styles. You can use a die grinder and/or special washers to correct this, but if you don't have to...
I also never heard what carb you were going to use. A holley (squarebore) or a q-jet (spread-bore style)?
Ya know what? I couldn't find it just now. ?!? Did they not make it for post 1987 engines??
Old Dec 24, 2007 | 10:01 PM
xpndbl3's Avatar
Car: 1984 Z28
EDL-2604 $259
I doubt a dual plane would feel soggy down below, and the performer is more restrictive than the performer rpm either way
Old Dec 24, 2007 | 10:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
That's what he just listed above there. Dual plane yes, but not performer RPM. That's just the plain jane performer, albeit air gap. So
Just so everyone else is all on the same page, Performer and Performer RPM are both dual planes, Victor Jr and higher (or other brands) use single plane, typically associated with higher RPM usage.
Old Dec 24, 2007 | 10:10 PM
xpndbl3's Avatar
Car: 1984 Z28
hmmmm yea you're right not an rpm, i can't find it online, i know i've seen them before.
Old Dec 24, 2007 | 10:51 PM
Car: 88 IROC-z
Engine: LO3 V8 305
soooo wat do i want for an manifold?
Old Dec 24, 2007 | 11:05 PM
jstoltz's Avatar
just go with a performer rpm
http://store.summitracing.com/partde...1&autoview=sku
or if you have more to spend this one.
if you can find either one on Ebay for cheaper go for it. they are both 86 and down intakes. easy mod needed to use for 87 and up. if you don't feel like trying to mod it yourself most machine shops will do it for around $30.
Old Dec 25, 2007 | 12:32 AM
Sonix's Avatar
Car: 1982 Trans-Am
You still haven't said what carb you're going to use. You need to get the right manifold for your carb (or later you buy the carb that you need for that intake eh?)
The performer RPM is a good one as mentioned, just mod it. Or get the Performer air gap that you linked to before. Just make sure you've got the right carb for it eh?
Old Dec 25, 2007 | 03:30 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I myself am going with the professional products crosswind intake. It is the lower priced ripoff of the airgap I have had both intakes and cant tell a diffeence with the butt dyno airgap/crosswind best intakes for sbc imo and for carb I would recomend a speed demon
Old Dec 25, 2007 | 05:16 AM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
What heads will you be using? An upgraded manifold is useless without them. You won't see any performance advantage with just a manifold and carb.
Old Dec 25, 2007 | 07:45 AM
Car: 88 IROC-z
Engine: LO3 V8 305
i think im gunna just buy the manifold and stick wit TBI just get an adapter plate for the TB. people are saying to do that. but i dunno im new to this TBI **** and know a lil about carbs. soo what do u say i should do? do u think its worth changing the Intake and using my TB? or should i just replace the intake and go carb? ill be using stock heads for a while until i get sum more cash for better heads. mb go 350 who knows
Old Dec 25, 2007 | 09:31 AM
xpndbl3's Avatar
Car: 1984 Z28
why not just not mess with doing things twice and just save money until you can afford to drop in a 350 and just enjoy your good gas mileage while it lasts
Old Dec 25, 2007 | 09:45 AM
jstoltz's Avatar
I second that or get the carb and intake now whatever you want to do. the intake swaps right over to the 350.
Old Dec 25, 2007 | 09:55 AM
Car: 88 IROC-z
Engine: LO3 V8 305
well i really dont wanna do a swap,. i rather keep this engine. cuz i dont have the tools to do the swap. how much will it cost to do a swap? Also do u think its worth to get a carb intake manifold and use a TBI adapter and use the TB?
Old Dec 25, 2007 | 10:06 AM
Engine: 400
I don't see any big gain for the money and time. And buying a carb for a 305 isn't a great idea, since it will then be too small for a 350, so you're wasting your money.
Maybe you said you have the exhaust done already, but if you don't, buy some headers and a catback system.
Old Dec 25, 2007 | 10:11 AM
Car: 88 IROC-z
Engine: LO3 V8 305
yeah i got a flowmaster 80series muffler. i am getting shorty headers and custom y-pipe then doin straight pipe to muffler. also wanna get an LT1 cam. but im still wanting to knowk about intake. as in what i should do.
Old Dec 25, 2007 | 10:13 AM
Engine: 400
I wouldn't waste your money on it. Save for a 350. The swap isnt difficult and you buy the tools as you go.
Old Dec 25, 2007 | 10:33 AM
  #42
Car: 88 IROC-z
Engine: LO3 V8 305
i guesss illl save, thanx again.
Old Dec 25, 2007 | 12:37 PM
  #43
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
I bet you could get used 350 heads and block for the price of a edelbrock manifold. a mild 350 is way better than a maxxed out 305.
Old Dec 25, 2007 | 12:55 PM
  #44
Car: 88 IROC-z
Engine: LO3 V8 305
Hey how much do you think a complete 350 is? Ur talking about just the block n heads. Don't I need all the parts to go wit it? I can't rebuild an engine lol. I kno sum stuff not all tho.
Old Dec 25, 2007 | 03:55 PM
  #45
jstoltz's Avatar
just look in a trading post or call a junkyard you can find stock 350's for around $300
Old Dec 26, 2007 | 04:20 PM
  #46
Engine: 400
I found my rebuilt, running carb to pan 400 small block for 600 bucks. Had maybe 200 miles on the rebuild. That's one nice thing about Chevys. There are always good deals around if you look. Get on a local racing board and I'm sure there is good stuff for sale.
Hell I bought a non running complete intake to pan 350 for 24 dollars. Needed a rebuild to be reliable.
Just gotta start meeting people in your area. Everyone knows someone who knows someone. That's where the good deals are
