benifits of tpi to carb
Old Jan 30, 2008 | 03:51 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
ive been thinking of swaping my tpi out for a carb set up for hopes of more power i already have a nice tpi set up everything is in my sig but my question is will i have more power with a carb and what about driveability cause right now it sucks since i have a decent size cam with out a tune, it doesnt really run smooth till about 3500, i dont care about fuel mileage, i have everything laying around my house and shop to do the swap besides a manifold so what type of manifold you guys think would work well for me with a q-jet carb, i have about 10 of them laying around not sure which one im going to use yet, the car is only really used for the track and and having fun on the streets, thanks
and ill also be swaping to hooker 2210s with true duals when i do the carb swap if that makes any difference
Old Jan 30, 2008 | 04:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's a pretty big cam for a 305 TPI.
Performer RPM and 650 double pumper carb.
Benefits would be being able to take full advantage of the cam.
Old Jan 30, 2008 | 09:17 PM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Re: benifits of tpi to carb
yea thats what i was thinking with the cam cause its never run as good as i think it should thats why i thought a carb would be better, a guy i know has a edelbrock performer for sale for 50$ so im going to buy that at the end of the week, and is the holley that much better then the q-jet, i have one that i just took off a 78 vette, that was just rebuilt 2 months before i replaced it, would it be better then the 650dp
Old Jan 30, 2008 | 10:50 PM
five7kid's Avatar
The Performer isn't enough intake for that cam. You really need the RPM version.
With a manual transmission, a double pumper is your best bet.
Old Jan 30, 2008 | 10:54 PM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
ok thanks alot for your help im going to start looking on ebay for a manifold and carb, is a 650 db a square bore flange or spread bore, this is my first time using a carb so i dont know much about them
Old Feb 1, 2008 | 12:52 AM
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
The majority of Holley's carbs are square bored, with the exception of a couple of models.
Old Feb 1, 2008 | 11:20 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're already running 12.92 with a 305 TPI! What more do you want? I think if you get the computer tuned you'll enjoy the car a lot more and will get that silly idea of going backwards with old technology out of your head.
Is this a race car or a street car? Race cars use carbs because they dont care about torque. Street cars keep the TPI because the torque is awesome and comes on where you use it on the street, from idle to 3500 rpms.
Its always been my opinion if you want a carb car then buy an 87 or older one that came with a carb. Dont hack up a TPI car, sell it to someone who appreciates TPI and is willing to work with it.
Old Feb 1, 2008 | 11:46 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
tpi is old outdated technology just like carbs Kevin
I don't see a well setup carb setup making any less torque than a tpi setup at all.
Old Feb 2, 2008 | 02:31 AM
Kevin91Z's Avatar
Not on a thirdgen. TPI is newer and more recent technology than thirdgen carbs are.
Carb manifolds have short runners to keep the fuel from falling out of suspension with the air. The short runners also promote horsepower at the expense of torque. TPI's long runners promote torque from idle to 4000 rpms at the expense of horsepower above 4000 rpms. An engine with a carb manifold will not make the same torque across the power band as a TPI manifold will. The physics are completely different.
Plus I like plugging in my laptop and adjust the fuel and spark tables without having to get out a screwdriver and getting gasoline and dirt all over my hands. But some people like that stuff.
Old Feb 2, 2008 | 05:25 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
well thinking about this from a different perspective, I like to know what heads your using on this engine? are they factory heads or aftermarket. The reason I ask is the Performer RPM intake port runner size is big! It actually measures bigger in size than a victor jr port. If you use the RPM manifold I'd check the runner size to be sure its not bigger than the head port. If it is, you'll be having major reversion in the manifold and port flow will be compromized for sure. Stock 305 heads port size are extremely small and to open them up to acommadate a RPM or Vic Jr manifold just may kill your torque down low.
I'd say stick with the TPI and work with it like Kevin said. The TPI was designed initially for the 305 rather than a 350.
Old Feb 2, 2008 | 07:22 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 89305formula
ive been thinking of swaping my tpi out for a carb set up for hopes of more power i already have a nice tpi set up everything is in my sig but my question is will i have more power with a carb and what about driveability cause right now it sucks since i have a decent size cam with out a tune...
The power your making will be much more linear with a carburetor, yes, but it would be the very same difference w/EFI if you swapped to a Holley Stealth Ram, w/new prom burned....
Old Feb 2, 2008 | 08:12 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Umm wasnt the TPI originaly designed for the corvette with a 350?
Old Feb 2, 2008 | 08:57 AM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
there pro comp 180cc heads ported to a 1205 felpro, and the car is a street strip car but its going more towards a race car but it will always be street legal, i dont really care about driveability or mpg if it will make it faster on the track ill deal with it on the street i want to go mid to low 12s on the motor this year and hopefully low 11s on the juice
Old Feb 2, 2008 | 09:02 AM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
and another reason i want to go to carb is because i have a miss that i have never been able to find and i lose injector pulse at random times and i cant figure it out for the life of me so i think a carb will just be easier cause im 99% sure its not a ignition problem, and ill probably be using a wieand stealth manifold and a 650db, does anyone know if this will fit under a stock hood
Old Feb 2, 2008 | 12:53 PM
Abubaca's Avatar
I used to feel that there was no need to go backwards in technology, but honestly, I think you could argue the "no need to backwards" argument with anyone not running an LSx engine. We've come so far in the past ten years, that unless you're cutting edge, you're really just old technology anyway.
So do whatcha want. Carbs are cool too!
Old Feb 3, 2008 | 09:17 PM
Kevin91Z's Avatar
LS1's are for 4th gens and we are dealing with thirdgens here. My biggest beef is the conversion of a perfectly good TPI car over to a carb. There are lots of people on this board who would kill for a good running TPI setup like you have.
But if its a drag only car, do what you want.
Old Feb 6, 2008 | 03:13 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Just get a Stealth ram like I did. I would never ever go from EFI back to carb. You will lose a ton of driveability and tuneability. Don't do it, for the love of God. If you plan your EFI out well, it won't lose you any power over carb. A stock TPI of course gives up power to an old fashioned Holley setup, so ditch the stock TPI intake and get something modern and short-runner.
Old Feb 6, 2008 | 09:09 PM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
i was thinking about that but i already bought a manifold, carb , and a regulator so im going with a carb, im probably going to keep the tpi stuff for a little while so if its not what im looking for ill go back to efi, plus the track opens in a few weeks so i need to get this thing together
Old Oct 5, 2009 | 10:46 AM
5.7TPI's Avatar
-Good overall choice going with the carb - TPI (being nice for the street ) will not give you hp numbers like a good carb set up will (due to flow restrictions) - do you see many strip cars with TPI ?
not unless you have 10000 bucks in it right- although I am a fan of the tpi - when I did my swap I was more then impressed also when sensors brake now it dont cost me 100$ here and there - Ohh wait no more sensors = no more problems
Ps- Doesn't everyone H8t thoes stupid fuc*ing torks blots!
Old Oct 8, 2009 | 03:55 PM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
on an opposite note, would a tpi set fit in a carbed 400 block? i've been throwing around the idea of doing a tpi swap but thought it might be too much of a pain to wire everything up. i dont drag race too much and wouldnt mind more torque.
Old Oct 11, 2009 | 05:36 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
The main reason behind swampin in a carb for my tpi setup is because I am DONE with all this Computer BS! It is much easier and cheaper to tune a carburator, all you there is to adjust is a screw and your good to go, you dont have to have a tuner or computer with you to adjust it. You can only add so much to a tpi setup until you start wastin your money. The TPI setup is limited, yes you can change it to a stealth ram setup but your gunna spend more money then on a carburated setup.
Just think you can spend the same amount of money on parts to upgrade your engine but when it comes to switching the intake to utilize it all you are saving a bunch of money but going carburated
Old Oct 11, 2009 | 06:38 PM
Yes, but the stock runners would choke the engine up high, so be sure to siamese them....
Old Oct 11, 2009 | 07:37 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
If you're till looking to carb that car, I have a holley 650 DP spread bore. It's in pieces and needs a rebuild (obviously), but I have everything for it. 50 bucks and shipping and it's yours.
Old May 26, 2010 | 08:57 AM
jcon104's Avatar
you may want to be careful what heads you are using also tpi heads will not work with a carb due to there being holes where the injectors where suppose to be
Old May 26, 2010 | 10:34 AM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
The holes for the injectors are in the intake manifold, not in the heads.
Old May 26, 2010 | 10:51 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You also lose streetability with a carb. The other problem is that technically, according to Federal Law, you shouldn't be removing the EFI equipment from the car. Your state may not do emissions testing, but that doesn't make the swap legal.
Old May 26, 2010 | 11:31 AM
cricket5150's Avatar
Car: 89' GTA
Engine: Stock 350 TPI
Axle/Gears: Stock
I've got a 91' RS.I tore the old,wore out,170hp 305 last year.I bought an Edelbrock 383 custom built engine which is rated at 450hp.The problem that I am having now is fabricating the electric fuel pump,turning it into a pickup and sending unit.Having to run all new fuel lines and finding the right throttle bracket that works.If I had known what I was getting into,I believe I would have stayed with the 305 and built a computerized high performance power plant...My biggest worry is doing the modification of the wiring harness,considering half of the wires I'm not going to be using.If this car wasn't spotless and in awesome condition inside and out,this car would be sitting in a junkyard rotting away...
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
