TBI to CARB - Kickdown/Thorrtole cables *NEED HELP*
Old Mar 3, 2008 | 12:26 AM
Parts4sale's Avatar
So I swapped out my TBI intake and TB for a edelbrock 1406 carb and edelbrock performer intake the problem I have now is getting the cables hooked up i know i need this adapter:
the bracket kit i bought doesn't work (it sets the cables to far back) and im getting frustrated what bracket kit do i need to hook up my throttle cable and 700r4 kick down cable? Or do I need different cables other then the TBI cables i have on the car? any help would be greatly appreciated
Old Mar 3, 2008 | 05:42 PM
Parts4sale's Avatar
Re: TBI to CARB - Kickdown/Thorrtole cables *NEED HELP*
bump, can anyone help me?
Old Mar 3, 2008 | 06:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I used the Edelbrock 8030 throttle bracket. I believe I had to redrill a hole or two to get everything just right. But it's a very sturdy bracket, nice chrome finish, and very adjustable - it will hold the throttle cable and the TV cable, and I think you could add the cruise cable in as well (with a cruise setup from a carbed car).
Old Mar 3, 2008 | 09:36 PM
Parts4sale's Avatar
Thats the same braket kit i bought! thats the one i was talking about that set them back so far
Old Mar 3, 2008 | 09:49 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
i just used the cheapy autozone bracket and redrilled the holes to put it where i needed it... its really easy to do just hold it in place and mark your holes.
Old Mar 4, 2008 | 01:22 AM
Parts4sale's Avatar
hmmmm, thanks, but is there any that i can jstu bolt on and that maybe has some adjsutments for the cables?
Old Mar 7, 2008 | 12:04 AM
rockin rs's Avatar
I went from tpi to an edelbrock 750, and I bought the cheap *** mr. gasket bracket from O'reillys. It set the throttle cable too far back, so I just cut the sleave around the cable so that it had enough play to fully open the throttle.
Old Mar 11, 2008 | 01:28 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
just get an old bracket off a nova or somthing, it bolts to the intake and makes your **** go back enough to fit right
Old Mar 11, 2008 | 02:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get a bracket off of a carb'd 3rd gen.
The one I have available is for a TH200C, which I don't believe is the same as TH700. I'll try to look at both tonight and let you know.
Old Mar 18, 2008 | 08:54 PM
91'ss''s Avatar
Car: 91 RS -- "SS"
Engine: 305 TBI
Transmission: WC T5
i got lucky strolling through the junkyard and found a carb'd transam and picked up the bracket for $5 and some change. if you have one around you, might be worth a shot
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
509 camaro fan
Sep 6, 2015 10:43 AM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
