750 dp help
Old Mar 9, 2008 | 04:28 PM
buzzzzz's Avatar
Car: 1986 IROC Z28
Engine: 383 Stroker
Transmission: built th350
Axle/Gears: 4:56
750 dp help
Where should the floats with the plastic site plugs on a 750 holley DP with mech. secondaries be set at? Do you go by the fuel or the looking at the float itself? I know the front should be just below the plug hole but what about the rear? Thanks
Old Mar 9, 2008 | 05:26 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: 750 dp help
set the rear just below the sight hole. front should trickle out the sight hole. Check with engine running.
Old Mar 9, 2008 | 05:49 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 750 dp help
Old Mar 9, 2008 | 08:06 PM
buzzzzz's Avatar
Car: 1986 IROC Z28
Engine: 383 Stroker
Axle/Gears: 4:56
Re: 750 dp help
Ok, but I thought with those ( clear ) ha. site plugs... I didn't think you would have to unscrew them. They're pretty fragile I might as well get the normal ones.
Old Mar 9, 2008 | 08:15 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Re: 750 dp help
I would. More accuracy.
Old Mar 9, 2008 | 09:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The clear ones are for tuning only. You aren't supposed to leave them on when you run.
Old Mar 9, 2008 | 09:42 PM
buzzzzz's Avatar
Car: 1986 IROC Z28
Engine: 383 Stroker
Axle/Gears: 4:56
Re: 750 dp help
Boy do I feel dumb but they were on the car when I bought it. Thanks five7
Old Mar 10, 2008 | 12:36 PM
five7kid's Avatar
No need for that. It isn't well understood (I didn't up to about 2 years ago), but they don't stand up to constant fuel exposure.
BG, QFT, some others build the site windows into the bowl - nothing to unscrew. The way Holley should have done it (I believe they are in some models now).
Old Mar 14, 2008 | 07:24 PM
buzzzzz's Avatar
Car: 1986 IROC Z28
Engine: 383 Stroker
Axle/Gears: 4:56
Re: 750 dp help
Ok I finally gave it to an expert and found out it has so many problems in the secondary side I'm having it checked to se if it;s worth fixin or buy a custom local built.
Old Mar 14, 2008 | 07:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: 750 dp help
"problems" how?
blocked passages? just drop them in carb cleaning solution, sold in a gallon pail like a paint can and then blow out with compressed air.
Old Mar 14, 2008 | 08:52 PM
buzzzzz's Avatar
Car: 1986 IROC Z28
Engine: 383 Stroker
Axle/Gears: 4:56
Re: 750 dp help
The needle screw threads in the top of the float bowl were stripped out, no power valve they were blocked off, #82 jets, warped throttle plate, no top vent tubes, need I say more........
RedLeader289
May 28, 2019 01:47 PM
Briandrex
Oct 5, 2015 06:20 AM
thekurlyone
Sep 30, 2015 12:54 PM
RedLeader289
Sep 23, 2015 06:50 AM
mackjar66
Sep 14, 2015 01:17 PM
