fuel pump relay on a 84 t/a??
Old Apr 10, 2008 | 12:31 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
ok.this is a really stupid ?
i am in the middle of my header install. i have my 3 wire heated o2 sensor. i have read that installing it to the fpr is the best place.(is that true?)
problem is i don't know where its at. i have 2 relays on the driver side of my t/a. 1 is down by the evap cannister the other is on the fire wall just under the actuator to open the door in my hood scoop.
any help is greatly appreciated.
thanks.jay.
Old Apr 10, 2008 | 11:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, that's not the best place to tie it in. You want something that is powered while the engine is warming up, and open when warmed up.
Search for the topic filtered on username "Vader".
Old Apr 10, 2008 | 05:15 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Re: fuel pump relay on a 84 t/a??
sir.
hey man while i got u on here. i removed the pass side manifold and there is a sensor in the block in betwwen the spark plugs near the back. the connector crumbled in my hands. what is that?? i need to buy one.
thanks again.
Jay.
Old Apr 10, 2008 | 05:40 PM
five7kid's Avatar
That's the switch for the electric radiator fan.
Old Apr 10, 2008 | 05:42 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
i found it,but its the sensor its self. wich i will replace,but what do i do about the trashed connector. i can make somethin that will protect it from heat,but i was hopping for a replacement.
thanks again. i'm still searching for the diagram u spoke of. its so much fun...l
Old Apr 10, 2008 | 06:13 PM
five7kid's Avatar
It's actually a switch, not a sensor.
I can find a connector for the knock sensor, which is similar, but not for that switch. If I come across something, I'll let you know.
Old Apr 10, 2008 | 06:22 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
ok cool. if not i'll make something thats heat resistant.
Old Apr 10, 2008 | 11:57 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
also i found this post but its so old that the pics won't load and its for an 84 like mine. can u help me out with a link?? u see i don't know what wire i ca use specifcally as a switched power sourse.
sorry i don't mean to be dumb here, this is all new to me. everything i've read just tells u how to wire the o2 its self. hell i've read so much to that effect i could wire it in my sleep. i just don't know what to wire too.
https://www.thirdgen.org/forums/tech...heated+o2+wire
Old Apr 11, 2008 | 03:17 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
ttt
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
