gaskets
Old Jun 8, 2008 | 06:19 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
gaskets
Which gasket should be used for a autonatic '85 Chevy E4ME? The application will be for a stock LG4 car and I want to drive for max fuel economy. The secondaries almost never get opened up (just driven to commute 10 miles).
Old Jun 8, 2008 | 07:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: gaskets
Use whatever matches what it originally came with, as it needs to match the manifold too, not just the carb. My L69 came with the open style gasket.
Old Jun 8, 2008 | 08:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: gaskets
I've only ever seen the open style...
Old Jun 8, 2008 | 08:36 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: gaskets
the closed gasket made me wonder. it's kinda odd because both appear to leave needed airways on this baseplate open.
Old Jun 9, 2008 | 12:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The open one is the proper gasket.
Old Jun 9, 2008 | 04:57 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: gaskets
Thanks!
Old Jun 14, 2008 | 10:25 AM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: gaskets
five7kid,
what is the other more closed gasket for?
thanks
Old Jun 14, 2008 | 11:09 AM
five7kid's Avatar
Been so long since I've seen one, not sure of the details. But, I believe early 70's q-jets.
Old Jun 14, 2008 | 06:41 PM
Air_Adam's Avatar
Re: gaskets
If I remember correctly, it has something to do with heat, *I think* from the exhaust crossover/hot air choke setup on some of the early '70s iron manifolds, and keeping heat away from certain parts of the carb (the 'closed' gaskets also used a thin metal plate under the carb as well).
Something along those lines anyway. Just use the open one and you'll be just fine
Old Jun 14, 2008 | 08:25 PM
five7kid's Avatar
The ones that had the heat passage up to the carb gasket had a nub on the driver's side up by the front mount bolt. Neither of those gaskets would cover it. From the 60's. The 396 originally had a q-jet on it, somebody had put one of those Holley econocarbs on it, I wanted a "real" q-jet. Finding a gasket that covered that exhaust passage wasn't as easy as you might think. Ended up using the plate/gasket multiple sandwich (which was supposed to be a heat insulator) as it had that built into it.
Anyway, just use the open gasket.
Old Jun 15, 2008 | 07:00 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: gaskets
Thanks guys, I put the open one on --
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
