Engine dying off idle
Old Oct 7, 2008 | 05:08 AM
BlueSSZ28's Avatar
First off, I'll admit i dont know much about carbs. On to the problem
Crank it and with it idling, it'll run and not die.
You can punch it and it'll get up in the high RPMs just fine, But, If you give it any certain amount of gas, and keep it STEADY. The rpms will react accordingly, then theyll gradually fall down and the engine will die (all within about 3 to 4 seconds)
When it starts to die, at anytime u can punch it and itll rev right up with no choking, no surging, no problems.
Feels like ur gradually letting off the gas and when it gets to idle speed it just dies (know thats not what its doing, just trying to explain best i can what it feels like)
Old Oct 7, 2008 | 05:56 AM
JohnyP's Avatar
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
Re: Engine dying off idle
are you letting the car warm up? what is your torque converter stall? what size carb/type with what engine...give us some more detail
Old Oct 7, 2008 | 05:59 AM
BlueSSZ28's Avatar
Yeah does it when its cold and after its warm.
Manual Transmission
LG4 305
4bbl qjet
Thanks in advance
Old Oct 7, 2008 | 01:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Computer controlled?
Old Oct 7, 2008 | 03:12 PM
BlueSSZ28's Avatar
Yes sir, Computer controlled qjet (Sorry, i forgot to mention that)
Old Oct 7, 2008 | 05:50 PM
five7kid's Avatar
Any SES light when this happens?
Is the accelerator pump squirting?
Can you hear the mixture control solenoid clicking?
Old Oct 7, 2008 | 06:46 PM
BlueSSZ28's Avatar
No SES
MCS is clicking
And to be honest, Not too sure how to check if the accelerator pump is pumping
Old Oct 7, 2008 | 07:39 PM
noroxus's Avatar
Car: 1984 Z28
Engine: 360ci SBC
Transmission: WC T5
Axle/Gears: 9 bolt 3.27 Posi
my beetle did this when it had a bad internal vacuum leak.
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
