My car stalls around turns!
Old Oct 16, 2008 | 04:04 PM
richcz28's Avatar
Car: 1984 z28 h.o.
Transmission: 5 speed
So I was whipping this right hand turn today and the car completely died. Tried it a couple more times same deal. This carb has been rebuilt this summer but I was very unhappy with the work. It came back with a snapped pin on one side, so it got sent back again. Then came back with a bad mixture control solenoid. I had to get it fixed at a mechanic because the carb shop told me it worked. (there was no clicking) I am in the middle of getting my money back, paid with a credit card. What is wrong with my car now? Any suggestions please. Can this be related to my cars mysterious problem of idling at 1500 rpms shortly after startup(with choke off) for about 5 minutes then idling at 700 again?
Old Oct 16, 2008 | 04:07 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: My car stalls around turns!
Blind question here, how full is your gas tank? Thirdgens (Fuel Injected or not) are notorious for an unbaffled tank and having fueling issues around corners when low on gas.
I'm not saying that this IS your problem, but it is a possible problem.
Old Oct 16, 2008 | 04:17 PM
richcz28's Avatar
Car: 1984 z28 h.o.
My gas tank was half full, well at the half full line. I was just told by a friend this could be the power steering pump locking up under hard stress?
Old Oct 16, 2008 | 08:39 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
I don't know what your issue is but I've had that problem before as well. It really sucked because I was at the top of a winding hill with at auto (no e-brake at the time).
Old Oct 16, 2008 | 09:36 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
that used to happen to me with my edelbrock 600, but it stopped when i got my holley.
Old Oct 17, 2008 | 07:35 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I dont see how your power steering has anything to do with your fuel pressure. Sounds to me like the pickup in the tank is sitting a weird way. Qjets are basically the best carb out there vs angles and sloshing.
Check your fuel psi at idle and when you rev it make sure its at least 4psi idle. Should hit like 7 reving it.
Old Oct 17, 2008 | 10:36 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I'm gonna go with your fuel gauge is off, and you're closer to 1/4 tank than 1/2. When I fly around corners on a low tank I lose all fuel pressure until the pump can suck up fuel again (stupid unbaffled tank).
Fill 'er up and see if she gets better.
Old Nov 3, 2008 | 11:55 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
happens to me when i park. pissed me off i live in ny drivers are psychos if you dont do stuff fast lol took me 10 mins to park my black b!tch lmao
Old Nov 4, 2008 | 01:24 PM
Guest
Guest
Posts: n/a
I believe the tank was half-empty.
Old Nov 5, 2008 | 06:14 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
What kind of carb is it.
I have had that problem with a few edlebrocs. Switched to a holley or qjet and the problem went away instantly
Old Nov 10, 2008 | 05:59 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
is your steering column loose? just asking since you said it happens when you are turning. I had one a few years ago that the plug on the column was loosing contact and killing it when I was turning. hope this might help
Old Mar 16, 2015 | 03:55 PM
Aerizanthar's Avatar
Car: 1984 Chevy Camaro
Engine: 2.8L V6
Transmission: THM 700R4
I'm in accord with the guys talking about the tank. I overhauled my power steering, no lockups or problems on mine, but has the same problem stalling around right hand turns when low on fuel, and by low i mean half a tank or less. The more g-force you apply, the more fuel can be in the tank and still stall. My thought on the matter is this:
Is it possible to replace the tank/fuel pickup to perform in high g-force scenarios? I once saw a rather expensive secondary tank accessory that could be installed in performance vehicles for this in racing, but i feel thats a bit much for just everyday street performance..
Old Mar 16, 2015 | 04:34 PM
richcz28's Avatar
Car: 1984 z28 h.o.
This was a long long long time ago....
The mixture control solenoid was junk. Which was really, cool, because it was functioning when the carb went out. I was only 20 at this time and hadn't worked on much before. I should have never gotten the carb rebuilt, because it worked before. I've lost 2 mixture control solenoids since. Have to love the eQjet
Old Mar 16, 2015 | 05:31 PM
Some swap to a 4th gen tank which uses a bucket, and should solve the issue.
There is also an external Swirl Pot fuel system. Basically, fuel is pumped into a small container which remains full, and excess fuel is returned to the tank. The engine is fed from the swirl pot meaning it has fuel at all times. This is probably what you are talk about with the secondary tank assembly.
Last and probably the easiest to install is the new Holley Hydramatt. Which is supposed to use surface tension of the fuel to seal off a porous mat that pulls only from the submerged sections. But its also not cheap. More money than converting to a 4th gen plastic tank I'll bet.
https://www.holley.com/news/articles...uel_reservoir/
Old Mar 18, 2015 | 04:20 PM
richcz28's Avatar
Car: 1984 z28 h.o.
I have no idea what this post is referring to? The problem has been solved.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
