extra parts E4ME
Old Nov 3, 2008 | 01:36 PM
Guest
Guest
Posts: n/a
extra parts E4ME
Hello, I have a 1986 Trans am, 305 auto. Im rebuiding the E4ME CCC carb on it. I have it apart now and I have rebuilt carbs before so this was definitely a newb mistake. But anyhow, I split the carb in three(in each of the 'bases') and when i turned the top base of the carb on its side(the top with the butterflies on it) two very small rods fell out(among other things) I dont have right now any pictures(should of thought ahead)but the rods are about one inch long and the diameter and likeness of a ball point pen and brass in color, both being hollow inside and open on both ends. The ends are rounded. I have scoured the forums and pics, but I cant see anything like this on it. Even my 'supreme' rebuild kit does not show this in its explded view. I would love to drive this again before it snows. Does ANYONE know where these went? I cant seem to find the spot and I am purdy sho these are needed to run. Thanks!!
Old Nov 3, 2008 | 02:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: extra parts E4ME
are they hollow tubes?
I doubt they are, it sounds just like your primary metering rods eh?
do they have little springs on them?
I know there's a rebuild blowup diagram here on the forum. You can check that. Do you have a digital camera?
Old Nov 3, 2008 | 02:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I had the same thing happen. They are supposed to be in the air horn, pressed into place. See https://www.thirdgen.org/forums/atta...ubes-boxed.jpg , which shows where they were when I pulled my airhorn off. They fit above those cavities.
Old Nov 3, 2008 | 02:10 PM
Guest
Guest
Posts: n/a
they are not the metering rods, they are still there. Also, i thought maybe these would slip over them or something, but to help, these openings in the rods arent large enough to fit the metering rods, if that helps.I have checked the posts here and the super awesome pics someone posted. I have an iphone, when i get home ill snap a pic or two with a tape measure and post them. thanks!!
Old Nov 3, 2008 | 02:18 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
https://www.thirdgen.org/forums/carb...jet-need.html?
Somewhere in the above Sonix outlined where these tubes (bleeds and emulsion) are installed in the airhorn.
Old Nov 3, 2008 | 02:23 PM
Guest
Guest
Posts: n/a
you are the frickin man. and you know what? I though about the fitting them in there but wasnt sure about the angle and WTH-why isnt this show in the exploded view of most diagrams?anyway, thanx a mil.
Old Nov 3, 2008 | 02:29 PM
five7kid's Avatar
They aren't shown because they are supposed to be a permanent part of the air horn, not "service parts" to be removed during servicing.
Old Nov 3, 2008 | 04:22 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Are we talking about the secondary well tubes that fall out? Just bang them back in w/ a plastic screw driver handle, being careful not to damage the ends
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
