retaining VSS???
Old Nov 11, 2008 | 08:01 AM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
retaining VSS???
im planning on going carb. this winter, yea i know, save the ranting.... but
i want to retain the factory VSS on the tailshaft of the transmission,
i originally thought it was computer controlled, i figured i would ask here. before i go and hack all my wiring out.....
thanks guys...
Luke
Old Nov 11, 2008 | 08:54 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: retaining VSS???
if its tpi i just found out you dont have the speed buffer box and you can forget it, however if its TBI you have the vehicle speed buffer box and you can wire it up from it, if its tpi you can order a speed buffer box and wire it like a tbi car to keep the vss option. you can view my wiring thread for wiring diagrams and troubleshooting if you have the tpi and have to wire it, the thread is called (wiring)
Old Nov 11, 2008 | 12:32 PM
Car: 92 Rs
its got TBI, so the way your saying is, i dont need to worry about it? if so thats awesome.
correct me if im wrong .
Old Nov 11, 2008 | 01:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should be fine.
Old Nov 11, 2008 | 01:44 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
How do you plan to lock your TCC? Normally, the PCM looks for the VSS signal to lock it.
Old Nov 12, 2008 | 11:17 AM
Car: 92 Rs
going with the TCC kit from bowtie overdrives.... i already have a BTO 700-r4, w/ a 3000 stall so it should be all good!!! and the BTO trannys already have the lock-up wiring installed.
so im safe once i get the kit
http://www.bowtieoverdrives.com/cata...php?ITEMID=334
Old Nov 21, 2008 | 10:25 AM
Car: 92 Rs
anyonhave any other input before i hack it????? haha
Old Mar 21, 2009 | 01:01 AM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
hows it work now?
Old Mar 26, 2009 | 09:12 PM
Car: 92 Rs
good, almost all buttoned up
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
