mech fuel pump?
Old Jan 19, 2009 | 06:54 PM
lotusstunts's Avatar
Car: 1989 IROC-Z
Engine: 406
Axle/Gears: 9 bolt 2.77s
mech fuel pump?
I have an 89 5.7 TPI I just put a new 350 in,edelbrock carb. basically i ran a mechanical fuel pump from the existing fuel lines, it does run, however seems to run out of fuel after about 10 mins. Do I need to remove the old electronic pump in the tank to have no problems? After stalling out it starts up after cranking over for about 15 seconds. then runs for another 10-15 mins. ahead of time
-Justin
Old Jan 19, 2009 | 06:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: mech fuel pump?
Which mechanical pump did you use?
Old Jan 19, 2009 | 07:00 PM
Car: 1989 IROC-Z
Engine: 406
Re: mech fuel pump?
not sure exactly, came with the engine, and seemed to be running fine before.
Old Jan 19, 2009 | 07:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: mech fuel pump?
Does it have a return line?
Old Jan 19, 2009 | 08:35 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Re: mech fuel pump?
Can a mechanical fuel pump pull fuel through the oem pump w.o the in take oem pump being powered on?
Old Jan 19, 2009 | 08:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: mech fuel pump?
no, the intank pump needs to be removed, or use it in conjunction with a good aftermarket fuel pressure regulator, and lose the mechanical pump.
Old Jan 19, 2009 | 08:47 PM
heff17's Avatar
Car: 89 Camaro
Re: mech fuel pump?
ok thats what i got goin on now with the intake pump and a holley reg.
Old Jan 19, 2009 | 09:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: mech fuel pump?
You can also power the intank pump with a mechanical pump, as long as it has a return line.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
