Holley
Car: 1984 camaro z28
Engine: L69 H.O
Holley
ok so i ditched the cc q jet and put on a Holley 600 car ran fine once i got it to idle took it for a drive and ran fine just a kind of dead spot stumble off idle on the way back home at a stop sign it just died now when i start it i have to keep my foot in the gas to keep it running i still have the stock distributor could this be the problem ? by the way this is all on a 1984 z28 with the l69 everything is stock except carb
Re: Holley
You probably need to tune your idle screws with the car in gear and the parking brake on. Hook up a vacum gauge, and turn the screws a 1/4 turn at a time allowing a few seconds for the motor to adjust. Keep adjusting until you get the highest vacum rating. Use the gauge to get an idea on the base timing as well. Look at one of the sticky posts above that is listed as Holley tuning. That will give you a more in depth adjustment.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Holley
Are you still using the L69 computer controlled distributor? If you are, thats part of the problem... it only works properly with the CC Qjet as well. Get a vacuum advance HEI if you are using the Holley.
Other thing - check the accelerator pump linkage on the carb, make sure you adjust all the slack out of it. Adjust it tighter untill there is just barely no slack in the linkage. If there is slack, it will not give a pump shot of fuel at the right time, and cause an off-idle stumble.
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Holley
morning from snowy Virginia. sounds like your car is running much better!
Personally, you might keep your stock carb & dizi & anything else associated w/ the carb/emmisions that you yank & set it aside for later. never know when you might want to try it again etc.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Holley
Engine: L69 H.O
Re: Holley
well whats the cheapest vacum advance hei distributor i can buy ive alredy spent 400 dollars on the car just this weekend i just want this thing to run
Re: Holley
This is the one I bought when I switched to carb. I've had great luck with it so far. It's basically a MSD copy with the jegs brand on it. It goes for $129. Suppose to be more on the performance side.
http://www.jegs.com/p/JEGS/761348/10002/-1
This one is the same type but is more of a everyday driver version I guess. It's only $89.99 right now. That's gonna be the cheapest good dist. you'll find.
http://www.jegs.com/p/JEGS/755778/10002/-1
Re: Holley
Could easily keep it way under $100 this way, and it will work just fine.
The new one posted above is a good choice too, but should also get the recurve kit if you get that.
Transmission: 4L80E/4L80E
The Mr. Gasket advance kit for HEI always made mine worse. A piece of junk in my personal opinion.
Engine: L69 H.O
Re: Holley
ok so i went out and changed the timing just a hair and now it idles and runs strong just stumbles off idle and backfires if you just slam it to the floor ? could this be my solution i really don't want to spend any more money on this car
You can advance it so it idles right. You can advance it so it runs right under power. You can advance it so it gets decent gas mileage.
But you have to choose between those three. You can't even have 2 out of 3.
Get a proper distributor or put the CC q-jet back on. Fixing it was probably your least expensive route from the beginning. But, who listens. . .
Engine: L69 H.O
Re: Holley
well we were fixing the quadrajet but my dad was rebuilding it and broke the plastic piece that goes over the float so he got mad and just went out and bought a brand new carb i guess i will go get a new distributor from the junkyard this weekend then
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
Re: Holley
If you pull a JY carb, I'd replace the Ignition module, or at least buy one and have the spare sitting around.
I had one go bad on me out of a JY carb in my old 85 Z/28.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Holley
You need to get the proper power valve in the Holley, go to their website for instructions, you will need a vaccum gauge, Power valces are $15 and the gasket kit $5 at Jegs. This will cause the hesitation to go away....
RaverRacerX
Mar 17, 2026 01:49 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
