carb install from tbi UPDATE !!!!!!!!!!!!!!!!
Old Dec 17, 2009 | 09:17 AM
  #101
killa66cam's Avatar
Re: carb install from tbi UPDATE !!!!!!!!!!!!!!!!
Originally Posted by Pre-Tuner
I think they might have blue also. I chose red because you can't get the TV cable adapter in any color except red. It is only available by Holley as opposed to the regulator bracket and throttle cable that you can get from Summit. After seeing the Summit stuff, I'm convinced both are manufactured by the same company, and the TV bracket fit (and matched) the Summit bracket perfectly.
I am using the Aeromotive 13301 bypass regulator instead of what everyone else seems to be using because I kept the intank pump...and I already had one. The only modification I had to do to the bracket was drill a couple of holes to mount the regulator and get longer screws to do it. I also had to modify the air cleaner by drilling a hole in it that the adjusting stud passes through. That took some time because if it would have been off even a little, I would have had to scrap the air cleaner. The hole is perfectly sized to the stud so nothing (debris) can get past it. I was initially going to put a grommet on it, but if it broke loose, the only place it was going was straight into the engine.
One other note about the way I did this is that the AN-6 hose can't make the corner into the carb. The only way around this was to cross the hoses and go to the other bowl (left side reg to right side carb). I'm not happy with the way this turned out, so I may eventually bend and flare some pipe.
I will be keeping the in-tank pump as well. I have a Mallory #4309 afpr is the only reason I was asking about the regulator. Don't know how much difference there is in the two though.
I don't particularly care how things are done or run, as long as it all works. I will take everything to my mechanic and let him figure it out anyways. Thanks.
Cam
Old Dec 17, 2009 | 09:18 AM
  #102
killa66cam's Avatar
Originally Posted by one92rs
hey buddy they do come in different colors. i am using a jegs throttle bracket and it is anodized black. and it was 69.00 plus the trans cable bracket was a little more. both were the same as the holley bracket. im using the barry grant afpr since it has a port for a pressure gauge.
Could you post links to those too?
Cam
Old Dec 18, 2009 | 05:45 AM
  #103
one92rs's Avatar
Car: SOLD!!!!!
http://www.jegs.com/p/JEGS/JEGS-Bill...52613/10002/-1
Old Dec 18, 2009 | 06:35 AM
  #104
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Does anyone know if there is a bracket like this that also has a mount for the control cable?
Old Dec 20, 2009 | 11:10 AM
  #105
one92rs's Avatar
Car: SOLD!!!!!
when you click on the bracket above to buy it will offer the control bracket lower on the page.
Old Dec 20, 2009 | 06:30 PM
  #106
mos68x's Avatar
oops, I apparently didn't type a word... CRUISE... control, lol. I meant to ask if anyone had seen any brackets that also allowed the use of the cruise control with the throttle? So far all I've seen have been TV cable and throttle brackets, none have ever said cruise control.
Old Dec 20, 2009 | 06:47 PM
  #107
Pre-Tuner's Avatar
Car: '91 Chevy 1500
That would be nice wouldn't it? I haven't seen one.
Old Dec 21, 2009 | 09:40 AM
  #108
killa66cam's Avatar
Appreciate it.
Cam
Old Apr 19, 2010 | 06:16 PM
  #109
one92rs's Avatar
Car: SOLD!!!!!
TTT
Old Apr 19, 2010 | 10:35 PM
  #110
Evilution's Avatar
Car: 1988 firebird formula
Engine: 305/ soon to be carbed
Transmission: 700r4 / soon to have stall
Axle/Gears: dunno but i have 4.10's on the way
can i get a part number for the distributors that work for a carb swap. i am not sure if these are flat tappet or roller cams so i dont want to buy the wrong one.
Thanks,
Marty
Old Apr 7, 2011 | 09:50 AM
  #111
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
saving info
Old Jul 14, 2012 | 09:49 PM
  #112
mudguy1990's Avatar
Car: 1990 chevy k1500 w/6inch lift carb.
Engine: 350 sbc 400hp 375tq
Transmission: 5speed manual
Axle/Gears: 10 bolt stock 3.73 on 35's
what did you do to keep your speedo working when you pulled the ECM out i have a 1990 chevy carb.
Old Jul 14, 2012 | 10:17 PM
  #113
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
the speedo is connected to the tranny, mine still works "fine" it sweeps up and down sometimes
Old Jul 14, 2012 | 10:20 PM
  #114
mudguy1990's Avatar
did you take the ecm all the way out of is it still pluged in?
Old Jul 14, 2012 | 10:25 PM
  #115
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
i left it plugged in, it doesnt bother anything....
Old Jul 14, 2012 | 10:33 PM
  #116
mudguy1990's Avatar
oh well i cut out all the ecm crap put and cleaned it all up thank you thought
Old Jul 15, 2012 | 09:09 AM
  #117
Ramjet 305's Avatar
Car: 1991 Chevy camaro rs
Engine: Chevy 305
Axle/Gears: 28 spline axle, 2.73
Do you think a carter 600 cfm carb is too much for a stock l03 small block that's in my 1991 camaro rs?
Old Aug 22, 2012 | 03:11 AM
  #118
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
great thread! lots of useful info in here for my future swap, i'm sure i'll have some questions to add later
Old Aug 26, 2012 | 06:36 AM
  #119
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
Great thread I'm getting ready to go from tbi to carb on my ZZ4, holley 600, edelbrock rpm, and HEI as well...thanks for the write up!
Old Mar 5, 2016 | 11:44 PM
  #120
1988_f-bird's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 carburated
So I did this swap similarly, however I had a 2.8 multiport and put in a carbed 305, now I left the ecm in but disconnected some wires and now my speedo "electric", coolant temp gauge, and fuel gauge don't work, any ideas on how to make these work without going through ecm?
Old Mar 9, 2016 | 01:49 AM
  #121
brettr81's Avatar
Car: 91 Firebird
You should probably start a new thread in the electronics section. This is a pretty old thread.
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
pimp2303
Jul 27, 2017 02:03 PM
86IROC112
Aug 17, 2015 02:00 PM
bryan623
Aug 10, 2015 11:33 AM
