tps adjustment
Old Apr 30, 2009 | 07:22 PM
sheardog's Avatar
Car: 1987 camaro
Engine: 5.0 ccc q-jet
tps adjustment
hi guys,sorry if i sound like i keep asking the same thing but i am a little unsure about proper procedure. Question; when i check the voltage on the tps on my 87 camaro, is the engine supposed to be running, or the key on but engine off? ( 87 camaro 5.0 liter ccc-qjet e4me, auto trans.)
Any help is greatly appreciated!!
Old Apr 30, 2009 | 08:41 PM
king1960's Avatar
Re: tps adjustment
Key in on position ,engine not running. .5 V At idle and approx 4.2 v at wot.
Old May 1, 2009 | 06:11 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: tps adjustment
leave tps connected & then plug positive probe of digital multimeter into the middle & negative into bottom.
Old May 12, 2009 | 06:07 PM
sheardog's Avatar
Car: 1987 camaro
Re: tps adjustment
So when i plug in the meter do i slide the probes in where the wires feed into the connector? or will this damage the connector? I noticed that the connector has kind of a cover that unsnaps where the wires feed in. Also i was wondering if i should have the meter set for the lowest DC voltage setting or would that matter? Thanks!!
Old May 12, 2009 | 09:24 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: tps adjustment
leave theconnector on and plug probes into where wires are, it wont hurt the wires. you can try the lowest dc setting on the multimeter and if no reading then move to next stage until you get a reading. it will be between 0 and 5, like the second post lists.
Old May 13, 2009 | 06:27 AM
sheardog's Avatar
Car: 1987 camaro
Re: tps adjustment
thank you very much for the help, i just wanted to make sure i do this correctly as i know that this is a critical adjustment and my repair manual is a little vague (not to mention i am very inexperienced with carbs) thanks again and i will report my findings after i get them.
Old May 13, 2009 | 08:13 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: tps adjustment
De nada, took me forever to figure it out -- probably way longer than you -- !!LOL!!
Old May 27, 2010 | 10:40 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: tps adjustment
Ahh. Just the thread I was looking for.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
