The ULTIMATE Drop-Base Air Cleaner! (*sticky?*)
Old Jun 10, 2009 | 03:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I see lots of threads with people asking what air cleaner to use to get just that little bit of extra room so they can close the hood without having interference problems because of their air cleaner or because the intake is too tall.
Problem solved - with pics!
Most generic parts store 14x3 chrome air cleaners have a base with a drop something between 0" - 1.25". There are a rare few out there with a 1-3/8" drop. If you're like me, this isn't enough, even though it is close. Here's the solution:
This air cleaner I bought is a reproduction part for:
-1970-72 LT1 Corvette/Camaro
-1969 Camaro Z/28 (302ci)
-1966-69 Corvette 427ci 1x4bbl (L88)
This air cleaner will work with a dual-feed Holley carb, like a double pumper, because it was designed by GM to work with the above engines, which did come from the factory with dual-feed Holley carbs. It has a HUGE 2.00" drop! It has a large breather tube welded onto it, so you can use a crank-case vent setup similar to what your stock 3rdgen 4bbl or TBI air cleaner had, instead of resorting to breather caps that make a mess. It could also be blocked off. The base has no sharp bends in the stamping, its all fairly smooth curves, so air should flow fairly well over it, compared to alot of aftermarket drop-base air cleaners.
This one came from 'Corvette Central' and cost me about $110 + the ride. It came with a new base, chrome lid, wingnut, and 14x3 AC Delco air filter element. Even though its listed in their catalog as 'foreign made' all of these parts are very high quality. I was quite impressed with what I got, and I'm picky with this stuff.
Here are some pics I took when I got it today, so you can see for yourself how this air cleaner fits on a generic Holley carb (will also work with Quadrajets and Edelbrocks). VERY nice piece IMO... might even be able to use my Holley 300-36 intake with this.
Here are the pics:
Old Jun 10, 2009 | 04:01 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: The ULTIMATE Drop-Base Air Cleaner! (*sticky?*)
Looks like a great solution for me, but what are you doing for the tranny and throttle cable? Looks like there may be a problem there?
Edit, is this the correct one?
http://www.ecklers.com/product.asp?p...er-_-41255-_-X
Old Jun 10, 2009 | 04:23 PM
Air_Adam's Avatar
Doesn't look to me like there should be any problems with the throttle cable, looks like there should be enough room under the base. I don't know about the TV cable though, I have a manual trans.
And yes, that base looks like its the same as mine. I got the whole air cleaner, that one is just the base, but any 14x3 filter and lid should work with it.
Old Jun 10, 2009 | 04:38 PM
Engine: 388 Carb
Axle/Gears: 4.10
Thanks, How long of a stud for the carb did they give you? I dont want to get one that is too long and cut it down after throwing it through my hood.
Old Jun 10, 2009 | 05:09 PM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
How much gap is there betweet the lid and the top of the carb? It looks like it is really a close fit? Is there enough gap to get enough airflow at high RPM? I have seen this happen a couple times when there is not enough area between the lid and the carb and it starves for air at high RPM.
Old Jun 10, 2009 | 05:51 PM
one92rs's Avatar
Car: SOLD!!!!!
can you please take a pic of the other side where the linkage mounts.
Old Jun 11, 2009 | 03:10 AM
Air_Adam's Avatar
Depends on the lid you use (the base is available on its own)... the lid I got came with the whole kit, and its probably got something around 1/4" above the tip of the vent tubes. So probably around 3/8" or so above the choke horn at the tightest point.
As for the carb stud, they didn't send one, as this air cleaner works on all common 4bbl carbs, but the stud I'd need for my lid would only probably need about an inch of exposed threads for the wingnut. The center of my lid drops down really low right there, so the whole wingnut is under the level of the highest point of the lid. The really low drop doesnt look like impedes flow around it much though, as its also very narrow.
Old Jun 11, 2009 | 03:11 AM
Air_Adam's Avatar
I'll try to get you one tomorrow.
Old Jun 11, 2009 | 03:06 PM
FoodStampsz's Avatar
Car: 86 F-bird TA
Engine: 383
Axle/Gears: 4.10
how much for the jelly beans?
Old Jun 11, 2009 | 03:22 PM
Engine: 388 Carb
Axle/Gears: 4.10
I ended up buying this for a stud.
http://www.ecklers.com/product.asp?p...dept%5Fid=1182
My total with ecklers was about 70 after shipping.
I ended up buying an air filter assembly from summit for $20 after shipping
so all in all $90 and hope that it works!!!!
Old Jun 11, 2009 | 03:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This is the base that F-Bird'88 has touted in the past. He makes a few comments that may be generally helpful:
https://www.thirdgen.org/forums/tech...an-i-find.html
JamesC
Old Jun 11, 2009 | 04:02 PM
Air_Adam's Avatar
That stud looks about right for the lid I have... it would use a very very short one like that. But the lid they sent me has the wingun center 'dip' much lower than most aftermarket lids I've seen. If you are using a Holley 4160/4150 with a working choke, it looks like a 3" element is the minimum without the choke horn hitting the lid. The base does drop VERY low.
Here are the throttle lever pics that were asked for.. one is kinda blurry, but you can still sorta see. Lots of room in there. The stud poking out the side of the lever is for the throttle cable.
Attached Thumbnails The ULTIMATE Drop-Base Air Cleaner!  (*sticky?*)-dscf0050.jpg   The ULTIMATE Drop-Base Air Cleaner!  (*sticky?*)-dscf0052.jpg
Old Jun 15, 2009 | 01:18 AM
Air_Adam's Avatar
... Just wanted to add this to the thread - I installed my new intake today (a GIANT Holley 300-36, which is a good half inch taller than an Edelbrock RPM) with the carb and air cleaner in the pics, and I still have 1/4-3/8" hood clearance above the highest part of the air cleaner.
Old Jun 16, 2009 | 06:43 AM
csmith3's Avatar
Car: 70T/A, 87Formula, 02Hawk, 06 GTO
Engine: 400, 350, LS1, LS2
Transmission: M21, 700r4, T56, 4L65-E
Axle/Gears: 3:55, 2:77, 3:45, 3:46
Couldn't you use a K&N filter lid to avoid air starvation issues at high rpm? Just a thought.
Old Jun 16, 2009 | 01:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the lid didn't sit in the hood blanket, yes, it would help.
Old Jun 16, 2009 | 02:39 PM
Engine: 388 Carb
Axle/Gears: 4.10
I also want to add that I just recieved my base from Ecklers.
I had to do some cutting to get it to fit with my CSR throttle bracket. Also had to trim the back of it to fit with my large cap HEI.
On my Victor Jr Headed 388 I have a super victor intake manifold. This thing is SUPER high...
I have a Firebird Formula and I also had to trim under my hood, I trimmed up all the framework to the left of the bulge. I ALSO had to drill 2 holes in the top of the lid for the tubes that come out of the holley carb. (I have no choke) I probably should have bought the lid that Ecklers sold but I just dont have the spare cash right now. That might have solved the problem with 2 holes in the top of the lid...???
All in all the LEAST amount of space I have is about a little more than 1/8th inch after all the trimming. It sure beats getting a new hood then getting it painted...
If anyone needs pics of any of the modifications please let me know.
Old Jun 16, 2009 | 03:37 PM
Air_Adam's Avatar
I have an MSD distributor, which is about the same size as the small-cap distributors the later cars came with, so I didn't need to clearance anything for that. My stock throttle bracket also worked just fine. Lots of room there. No cutting needed on the lid for the vent tubes either, and they are unmodified.
Old Jun 16, 2009 | 04:22 PM
Engine: 388 Carb
Axle/Gears: 4.10
Yah, people with a coil-in-cap HEI unit will need to slightly modify the drop base, but the filter itself didnt need to be cut.
I spent alot of money on my CSR bracket with tranny cable so I really didnt want to have to get a new bracket, it was just easier to modify the base. I have to get the correct lid now...
Old Dec 20, 2011 | 09:05 AM
lonesomeloser's Avatar
Car: 1983 Z28
Do you think this base would fit a 4" element under my stock hood with an RPM intake?
Old Dec 21, 2011 | 09:11 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I think it will be tight. I have an RPM Air Gap, 1.5" spacer and a 3" element with this drop base and it clears my stock IROC hood, but just barely. The plus side is that the 3" element seems to be plenty for my 11 second car.
Old Dec 21, 2011 | 09:29 AM
Car: 1983 Z28
OK. I just want to be sure there is enough clearance between the lid and choke horn if I use just a regular edelbrock lid.
Old Dec 21, 2011 | 09:28 PM
Damon's Avatar
Guys, please remember that you need at least an inch of free height above the top of the choke horn (minimum) for the carb to meter fuel correctly. Having a big air cleaner is good, but you still need room for the air to "staighten out" before turning and flowing into the carb. If space gets too tight you can pick up weird bogs and stumbles that simply can't be tuned out.
Old Dec 23, 2011 | 07:29 AM
pancherj's Avatar
Car: 1990 IROC
my lid sits very close to the vent tubes. It may be about 1" clearance to the top of the carb body. Remember, GM engineered this lid (I am sure this wasn't attemp #1)... I haven't seen any loss of power on my car which runs 11.80's.
Old Dec 23, 2011 | 12:55 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i have a 1.5" drop base in the car and it hits the spectre throttle cable bracket. im sure the 2" would be impossible to use with it. i dunno about stock throttle cables. i had an rpm air gap, a holley, and a 3" filter and the 1.5" drop base and it all fit under the stock hood.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
