2 fuel pumps?
Old Jul 1, 2009 | 11:11 AM
Prime Target's Avatar
Car: 1984 Camaro Z28
Engine: L69
2 fuel pumps?
Anyone ever hear of 2 fuel pumps on a carbed motor? I have a mechanical one on the motor and I just dropped the tank yesterday and found the fuel sending unit has an electric pump attched to it also. Sending Unit(FEH) is original and has 3 wires in the harness.I was told previously that a carbed motor wouldnt have an electric pump in the tank and bought a used sending unit based on that information. WTF?
Old Jul 1, 2009 | 01:43 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: 2 fuel pumps?
Yes, GM added a pusher pump in the gas tank to help with vapor lock mainly on HO engines. Some 83's and 84's could have them added by the dealer and I think later years got them from the factory.
Old Jul 1, 2009 | 05:25 PM
Engine: L69
Re: 2 fuel pumps?
Thanks for the reply. I guess I will be sending the original one out to be refurbished. I have to buy a new tank also. I tried forcing air into the tank to reform it but it didnt work as well as I thought it would. It's a little confusing because the tank made for an in tank fuel pump has a larger opening for the sending unit than one w/o the tank unit. The used sending unit I bought from a thirdgen member does not have the fuel pump on it but still fits on the old tank. See the pics.
Attached Thumbnails 2 fuel pumps?-fuel1.jpg   2 fuel pumps?-fuel2.jpg   2 fuel pumps?-fuel3.jpg
Old Jul 1, 2009 | 05:40 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: 2 fuel pumps?
Got an electric one in the tank in my 1987 LG4.
Old Jul 1, 2009 | 05:44 PM
Engine: L69
Re: 2 fuel pumps?
Pics of the used one I bought.
Old Jul 1, 2009 | 05:52 PM
Engine: L69
Re: 2 fuel pumps?
My 85 IROC w/TPI had it in the tank also, but it did not have a mechanical one on the motor. I was suprised to find the L69 had both pumps.
Old Jul 1, 2009 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm confused about what you're saying here. I don't have a particularly large personal database, but I was of the understanding that all 3rd gen tanks have the same size opening.
That would be consistent with my understanding.
FWIW, I've got a used tank in great condition (California) car available. It is a non-electric-pump version, but as you observed, the pick-up with the pump should fit in it.
Old Jul 1, 2009 | 07:08 PM
Engine: L69
Re: 2 fuel pumps?
Thanks 57, but I think I found a tank. While I was shopping for a tank I was consistantly asked if the car was carbed or FI. When I asked what the difference was I was told the FI sending unit pump would not fit into the hole on a tank made for a sending unit w/o a pump. I have not seen another tank other than the one I pulled from my car, and I wanted to avoid ordering the wrong tank. You could be correct that all the tanks have the same size opening. I just want to avoid getting the wrong one if thats not the case.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
