upper rad. hose issues
Old Jul 25, 2009 | 08:36 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
ok i have searched and come up with no good answer i have a 92 T/A i swapped from TPI to carb on my intake i have one of the straight chrome water necks i cant find a hose to fit. i had one i thought would work but it hit the alt. now it has a hole in it. what hose do i use? i cant afford to replace the water neck or to get a flex hose right now. i can barely afford a hose. what do i do??
Old Jul 25, 2009 | 10:40 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: upper rad. hose issues
well to tell the truth the last hose i bought for an 1992 camaro rs with a 305 i installed on a water neck that went to the side. but i know for sure it would have fit on a striaght water neck. i do know that a tpi engine has a straight water neck on it.
Old Jul 25, 2009 | 11:49 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i hope you took everything off including every nut bolt wire and computer in front of the firewall and behind it.
it is worth some good money.
305 people like me are always looking to change out the tbi for tpi.
i bought a complete system from a 350 - everything.
Old Jul 26, 2009 | 01:40 AM
92whiteta's Avatar
Engine: 355
the tpi water neck went to the side and it was long. i tried it before i sold the setup it wasnt gonna work. my father in law has a hose from a tbi camaro and it wont fit a straight waterneck it curls over and collapses he has to go back the the turned one becouse it wouldnt fit the straight one he had.
Old Jul 26, 2009 | 01:07 PM
csmith3's Avatar
Car: 70T/A, 87Formula, 02Hawk, 06 GTO
Engine: 400, 350, LS1, LS2
Transmission: M21, 700r4, T56, 4L65-E
Axle/Gears: 3:55, 2:77, 3:45, 3:46
Why not use the neck and hose from a car that was originally carbed? That would be vehicles up to 1987. Should work fine.
Old Jul 26, 2009 | 01:59 PM
92whiteta's Avatar
Engine: 355
i dont have the neck from one nor the money to buy one. i said that earlier. i need a hose that will fit what i have
Old Jul 26, 2009 | 04:06 PM
92whiteta's Avatar
Engine: 355
ok i found a hose that fits well the part number is E71317 i had to cut about 3 inches off of the intake side but it fits about perfectly. im happy with it
Old Aug 7, 2009 | 12:56 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Where did you buy this hose from?
Old Aug 7, 2009 | 04:27 PM
92whiteta's Avatar
Engine: 355
advance autoparts
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
