Intake
Old Jan 17, 2010 | 06:21 PM
87_ta_305_4bbl's Avatar
Car: 87 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 bolt 3:52
Intake
hey 87 ta 305 with a 4bbl
im switching the carb to a holly because we all know quadra junk is exactly what it means and i reall dont feel like tuning an edelbroc evey time i want to drive the car so im going holly and no you all are not going to change my mind thats final but dose any one have good experience with an intake manifold that would work for my application please repond
Old Jan 18, 2010 | 12:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No.
Old Jan 18, 2010 | 02:14 PM
Car: 87 Trans Am
Engine: 305 4bbl
Re: Intake
Originally Posted by five7kid
No.
Thanx for no help at all broseph
Old Jan 18, 2010 | 02:45 PM
five7kid's Avatar
You don't seem very open to help, actually.
...im switching the carb to a holly because we all know quadra junk is exactly what it means ...
Only ignorant people "know" that.
... and no you all are not going to change my mind thats final ...
So if we can't convince you of the truth, why should we bother making recommendations?
...but dose any one have good experience with an intake manifold that would work for my application please repond
Certainly, but not if you're going to be closed-minded.
Old Jan 19, 2010 | 01:04 AM
Car: 87 Trans Am
Engine: 305 4bbl
Re: Intake
look if you were to read the whole thing and not nit pick my question i am simply stating what i am working with and what i have already and was hoping to find some one that had a similar set up to what i am planning on doing now if you dont have a set up like this or know some one that has a set up like this then stop typing on this thred and be done with it i want an intake that is going to work with a holly carb its as simple as that ok thanks have a great day im trying to be a civil about this as possible but your really starting to p!$$ me off so your done any one else
Old Jan 19, 2010 | 11:45 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Intake
1) We don't know what you have - is it all stock?
2) The Quads are about the best carb out there - great gas mileage, capable of alot of power, capable of feeding alot of setups
3) Your wrong on the Holley vs. Edelbrock - the Holley is the one that usually gets tuned more often - that's why it was designed to be more easily tunable. The Edelbrock is a plug and play, easily tuned in 10 minutes, and stays where you leave it without retuning all the time, but not quite as easy to change jets, rods, etc.
4) There's alot of manifolds available, but we don't know what you want really. Technically, if I understand it correctly, intake should be matched to the cam, carb should be matched to the intake - so you're kinda going backwards seeking an intake to match a carb.
So - in essence, get any intake you want that your Holley will mount to - it's kinda personal preference. Most carb folks use an Edelbrock Performer RPM or Edelbrock Air Gap if that helps.
Old Jan 19, 2010 | 12:25 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Intake
The edelbrock performer rpm and the air gap are too much for his 305. He will need a performer or a weiand action plus intake. And if you car is anywhere near stock you will need to ditch the computer,figure out a way to control transmission lockup,and you will need a new distributor. All in all you should stay with the stock quad unless you can change all the above.
Old Jan 19, 2010 | 03:17 PM
Car: 87 Trans Am
Engine: 305 4bbl
Re: Intake
Well my 305 is compleatly stock and the tranny is a jasper racing 700r4 the car dosent have much of a computer so that won't be hard to eliminate but thank you for the real suggestions I didn't want to go edelbroc because I have had nothing but problems with those had to tune them every day when I went to drive the car and I just really don't like quadrajets this one has been nothing but a hassel so I want to go to a holly so thanks for the weiand suggestion I appreciate it
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
