ENGINE LIGHT STAYS ON
Old Mar 17, 2010 | 05:52 PM
bayman's Avatar
Camaro was running perfect until I left my headlights on overnight. I removed and recharged the battery but now the check engine light stays on and won't go off. Car is running rough and won't idle.I am thinking that no power is going to the air fuel solenoid at the carburetor.Keep in mind the car was running,shifting and timing was advancing properly until headlights were left on and completely drained the battery.Please help!
Old Mar 17, 2010 | 05:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ENGINE LIGHT STAYS ON
Have you checked the codes yet?
Old Mar 17, 2010 | 06:02 PM
bayman's Avatar
Doesn't flash any codes and not sure how to check them. Scan tool that I bought from part store doesn't pull up anything.Only had this car for couple of weeks so really want to get this solved. Any help is appreciated
Old Mar 17, 2010 | 06:35 PM
bcmag's Avatar
isnt ther a fuse link or inline connector on these that comes off pos cable and powers ecm? possily unplugged or damaged when battery was removed?
Old Mar 17, 2010 | 06:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Retrieving error codes, and interpreting: https://www.thirdgen.org/service-eng...ht-error-codes
The ECM power is a wire connected to the positive battery cable, runs along the frame rail under the radiator overflow tank. Check out the connection there.
Old Mar 18, 2010 | 06:09 PM
bayman's Avatar
That was the problem...Thanks for the help
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
