Need help picking out an air cleaner
Old Mar 27, 2010 | 09:09 PM
mikeye90's Avatar
Car: 1992 Firebird
Engine: L03 : \
Axle/Gears: 10 bolt
I have a holley 770 CFM street avenger on a 400 that im swapping into my car, but the air cleaner that is on it wont fit on my stock hood, it was previously in a car with a cowl hood. What kind of an air cleaner do I need? I want some kind of low profile one that will sit low enough that I wont have a problem with hood clearance. Thanks in advance! links to summit as an example of something I'd need would be great!
Old Mar 28, 2010 | 04:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need help picking out an air cleaner
Most use a drop-style air cleaner base and a 14 in filter. I don't know about the Holley's, but on an Edelbrock carb you have to include a 1/2in spacer to raise the base off the carb enough for the linkage to clear. These spacer rings are plastic, and don't work worth a hoot in my book - they don't seal to the carb well, allowing dirt in. Plus, for many of us, the 14in air cleaners rub a plug wire.
I use a Spectre 9in cleaner - it's smaller and doesn't rub anything. It comes with a 2in filter in it that's cleanable and rechargeable (like a K&N with oil). It's not a drop base, so there's no linkage issues - but the top center is tall (kinda cone shaped where the center is slightly higher than the sides). I just put a long bolt through a piece of wood, and tightened a nut on the top gently until it bent down flat.
It fits fine under my stock hood - I have a Performer RPM intake and Edelbrock 1405 carb. And, it looks to me like it allows MORE airflow than the drop bases - they drop so much that you end up with only about a 1/2in space for air to travel through - with this I clearly have a complete 2in all around.
They sell on the shelf at Autozone for $29.95.
Old Mar 29, 2010 | 12:04 AM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
have any pics of it?
Old Mar 29, 2010 | 09:00 AM
Car: 1992 RS
Engine: Carbed 350
You can see it on my car in a few pics in my photobucket:
http://s287.photobucket.com/albums/l...=cleanbay1.jpg
Summit doesn't have any pics of it - P/N SPE-47708. Spectre website is www.spectreperformance.com - click catalog, then air cleaners, then scroll down
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
