Modified Holley 650 Questions
Old Mar 29, 2010 | 08:59 PM
ProjectBird85's Avatar
Car: 1985 Trans Am
Engine: Procharged Small block 355
Transmission: TH-350 modified
Axle/Gears: Richmond 410
So I took my car to the track this past weekend and what a dog. It wouldnt even spin the tires in the burn out box. Also on take off it was laggy as hell. About half way down the track it's as if I hit an invisible barrier like the car tripped up same problem on the dyno, fell down at 4500/4 psi. I had to back off the throttle and get back on it. Not sure why this is happening. Any suggestions on how to tune my carb?
Old Mar 30, 2010 | 12:37 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: Modified Holley 650 Questions
Some information on your combo would help. Heads, cam, carb, intake etc.
Old Mar 30, 2010 | 07:55 PM
Car: 1985 Trans Am
World sportsman 2 heads, not sure the C/C cam is a comps blower cam, Edelbrock single plane RPM intake. The engine was built for a supercharger. I think the carb needs some tweaking big time
Old Mar 30, 2010 | 09:57 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
does it have a supercharger now?
Old Mar 31, 2010 | 08:33 AM
Car: 1985 Trans Am
Yes. Procharger 600B 8-10 psi
Old Mar 31, 2010 | 09:47 AM
camaro8tysvn's Avatar
Car: 87 camaro
Engine: 355ci
Transmission: richmond 5 speed
have you back fired lately, power valves are known for blowing out, could be from one back fire. Especially if its an older carb. i used to rebuild mine Holley 650 power valve every spring just to make sure. This year i put one on that has the power valve protection valve. I' excited to see if that makes a difference.
Old Mar 31, 2010 | 09:51 AM
Car: 1985 Trans Am
I backfired some. But we just put the trick kit rebuild to it a few weeks ago. I'm leaning toward not enough fuel at WOT and the bowls are emptying out early. Im also going to install my surge valve with a longer intake tube to give more time for the air to get to the carb
Old Mar 31, 2010 | 11:21 AM
you're supposed to drill out the pv protection check valve for boosted engines and use the poly floats. are you using a boost reference fpr?
Frozer!!!
Jan 19, 2024 04:55 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
