Carburetor problem?
Old Apr 23, 2010 | 06:43 PM
76GMC's Avatar
Carburetor problem?
Ok I have a 350 engine but when I try to start it up white smoke pops out the carburetor and it wont start to idle. I have recently installed MSD distributor and 6-AL ignition system thanks
Old Apr 24, 2010 | 12:30 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Carburetor problem?
so your sayin it will run but not idle?
Old Apr 25, 2010 | 09:15 AM
76GMC's Avatar
It wont start or idle, I crank the engine and it goes POP and i dont want to break anything so I stop cranking
Old Apr 25, 2010 | 09:20 AM
86 LT1's Avatar
timing is most likely not right or firing order incorrect make sure wires are where they should be
Old Apr 25, 2010 | 10:01 AM
76GMC's Avatar
It seems like Im 180 degress backwards, I think my balancer was messed with and when it lines up for TDC its actually on the opposite stroke. I've moved my dizzy as far each way it can go and rewired it like 4 times and still no improvement
Old Apr 25, 2010 | 11:02 AM
86 LT1's Avatar
Bring number up to tdc line up rotor with number 1 on cap and it will either be correct or 180 off depending on stroke
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
