How do I select the right carburetor?
Old Apr 24, 2010 | 04:02 PM
marcopasco39's Avatar
Car: '84 Trans Am
Engine: L69 stock
Transmission: T-5 B-W
What would be a good edelbrock for my stock L69? Thanks
Old Apr 24, 2010 | 11:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Is your stock carb gone?
Old Apr 27, 2010 | 07:01 AM
Car: '84 Trans Am
Engine: L69 stock
Re: How do I select the right carburetor?
No, i have an old q-jet.
Old Apr 27, 2010 | 07:51 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
then keep using it.
Old Apr 27, 2010 | 08:05 AM
five7kid's Avatar
Originally Posted by 84 z28
then keep using it.
Exactly. It's much better than an Edelbrock. That's why I asked if you still had the original carb.
Old Apr 27, 2010 | 09:08 AM
Car: '84 Trans Am
Engine: L69 stock
any tips on tuning it up a bit? I'm not too familiar with carbs, but pretty tech saavy.
Old Apr 27, 2010 | 10:19 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i would start by replacing your fuel filter and checking all those numerous vacuum hoses for leaks. check the voltage on the TPS as well. you already have the better rods and hanger so i won't suggest that upgrade.
Old Apr 27, 2010 | 01:46 PM
five7kid's Avatar
Tuning what up?
Old Apr 28, 2010 | 01:30 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Ive got several books for rebuilding the Q-Jet if you need some jet and rod choices for either power or economy let me know and I will help Identify the ones youll need.
Old Apr 28, 2010 | 01:39 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
is the 84 electronic? E4mE
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
Mdenz3
Sep 17, 2015 08:36 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
