No Vacuum at idle, that's not normal?
Car: 1985 Pontiac Trans Am
Engine: 383 Chevy
Axle/Gears: Ford 9 inch, 4.10 gears, Det. Lockr
Ok so I have a 383 with a barry grant 750cfm dp carb, sports claw. The car runs great no problems, but I'm always tuning just for fun. Last year I got out the vacuum gauge and properly set the idle screws and everything worked out great. This year after reading about power valves I thought I would check the vacuum to see what power valve would be correct and the gauge reads no vacuum. Now when I increase the rpm a little I get some vacuum but only a little. I am using the correct port to obtain the manifold vacuum according to the carbs instructions, the front port on the passenger side.
I am running a crane energizer cam, .480/.480" lift 284° advertised duration (228° at .050")
Any thoughts???
Maybe I Should just not screw with it and call it good but you know how that goes, always looking to make the car run a little bit better!!
Any thoughts???
Engine: 383 Chevy
Re: No Vacuum at idle, that's not normal?
I have two small ports on the passenger side of the carb I hooked the vac gauge up to the one towards the front of the car.
Engine: 383 Chevy
Yeah sorry, both of these ports are on the baseplate of the carb
well darnit it should be intake vacuum.
http://www.barrygrant.com/fromBarryG...n%20Manual.pdf
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
maybe your vacuum gauge is not functioning correctly?
Car: '82 Z28
You're tapping into the ported one which as you've found out will work when the throttle is cracked open. Use the other port for reading vacuum with a gauge.
