CCC choke
Old May 18, 2010 | 01:10 AM
Awesome-X's Avatar
Car: 87 Camaro
CCC choke
I dug an 86 Trans am out of a field that its been sitting in for 10 years.
Starts right up, runs like a charm when warm, but I have a few problems.
The choke won't work. I would say its a vacuum line probably, does anyone have a line diagram?
My cruise control doesn't work. It feels like it tries to but it just can't seem to keep it. This is also vacuum related isn't it?
The original CC distributor is out of the car, and is being run off a vacuum advance one for the moment, without the vacuum advance hooked up lol (don't know where to hook that up at)
But it runs great, and accelerates like noneother.
I'd just like to get another problem or 2 sorted out on it.
Old May 18, 2010 | 01:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only thing vacuum related to the choke is the vacuum break (aka, "choke pull-off"). When cold and before started, the choke butterfly should be completely closed (after the throttle is opened slightly to allow the fast idle cam to be engaged). Right after starting, the choke pull-off should open the butterfly slightly. As the engine warms up, the electrically heated choke thermostat should open the butterfly the rest of the way.
The engine can't possibly operate properly with a computer controlled carb and non-computer distributor (nor will the cruise control). Get a proper distributor in there as soon as possible. The Service Engine Soon light should be coming on and staying on with a vacuum distributor.
Old May 19, 2010 | 03:18 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: CCC choke
Really?? So my CC distributor could solve all my problems? I never would have thought. You're right, it does come on and the only code it throws is a code 12 which in this case would be because of the missing distributor, correct?
Old May 19, 2010 | 04:45 PM
five7kid's Avatar
Missing signal from the distributor, correct.
But not the choke not operating.
Old May 19, 2010 | 08:44 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: CCC choke
See this is why you should stay as an admin, kid lol
Old May 21, 2010 | 08:23 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: CCC choke
Well I put it back in and timed it and the car runs better, but it didn't solve my cruise issue. I also adjusted the choke on the carb some, but I think maybe it needs a thermostat. Any other ideas, Kid?
Old May 22, 2010 | 10:14 AM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Re: CCC choke
Hey awesome I had a similiar problem with the cruise. Get a hold of the car's schematics. My brake switch was on its way out. A new one fixed that.
Old May 22, 2010 | 12:44 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: CCC choke
It wouldn't come on because of your brake switch? Wheres that located?
Old May 22, 2010 | 11:45 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: CCC choke
On your brake peddle under the dash. there is a 3/8 vacuum hose run thru the firewall, these sometimes crack like all rubber lines and people forget that its there and just blame the cruise itself thus removing all traces of it. and yes the switch gets hammered from frequent brake use.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
